HELP !!! open valves question
Old Dec 21, 2008 | 04:45 PM
EG6_978's Avatar
Default HELP !!! open valves question
i took off my cylinder head off my d16z6 to do a head gasket. when i took it off i notice 4 valves were open and the rest were close. my friend said i drop the valves caused by over reving or misshifting. i dont know what to do can this problem be fix or do i have to buy a new head. another friend of mines said it was fine . he said i have to take of the cams to close the valves.please help
Old Dec 21, 2008 | 05:06 PM
Sr420Det's Avatar
Default Re: HELP !!! open valves question
Never messed with the sohc's but it sounds like you have bent valves. Can you take your head off without pulling the cam, if so a few valves can be down. Why did you take the head off, did it break a timing belt or something?
Old Dec 21, 2008 | 07:43 PM
EG6_978's Avatar
i didnt take the cams off just the head. and the car was running before i took the head off. i took it off because i had a leak and replaced the gasket because my car wouldnt start one day .and i check the spark plugs i think it was wet with gas or oil. i have a turbo d16z6
Old Dec 21, 2008 | 08:28 PM
94excivic's Avatar
By the sounds of it I would say that because you didn't take your cam off those valves are in the open position. I bet the cylinder that those valves correspond to is at the bottom of it's stroke. However if those two conditions are not as described then you may have a problem. If the car was running fine previously don't worry about it. Your not starting problem probably has nothing to do with the valves in this scenario.
goo_punch
Nov 1, 2015 02:54 PM
r.etheridge
11
Dec 6, 2010 01:42 PM
HondaKing90
19
Feb 15, 2010 04:38 PM
shbrown
May 9, 2005 02:54 PM
Layziebtnh055
May 15, 2004 09:51 AM
