Classic Hondas All Pre-1988 Hondas.
1987 Si hatchback INJECTOR Question
Old Dec 21, 2008 | 03:48 PM
Extradition's Avatar
Default 1987 Si hatchback INJECTOR Question
My homie has a 1987 Si Hatchback with 2 bad injectors (keep in mind it's a MPFI, not Dual Point). I wanted to know the CC's of the injectors so I can source him a new set from the junkyard. Are they the same as the OBD0 Da's (I think they're 240ccs)? Are they 180ccs like the Non-Vtec Sohcs? Let me KNOW what's up if U KNOW (absolutely).
Thanks
Old Dec 21, 2008 | 03:51 PM
allgo88's Avatar
Default Re: 1987 Si hatchback INJECTOR Question
wrong section.
Old Dec 21, 2008 | 05:20 PM
78CITYTURBO's Avatar
Post a wanted ad here...good luck..
http://www.redpepperracing.com/forum...hp?showforum=7
Old Dec 21, 2008 | 07:36 PM
Originally Posted by allgo88
wrong section.
Did I ask if it was in the wrong section? No dumb****, thanks for absolutely NOTHING.
Thanks for the help but I can source the injectors myself I just need to know the CCs.
Old Dec 22, 2008 | 09:41 AM
85ZC's Avatar
Banned
The 85 - 87 CRX/Civic Si uses 195cc injectors. The 240cc injector from a 86-89 Integra have been used before in some applications, but I hear this causes it to be rich, even using the 86-87 Integra ECU. I beleive the 88+ Civics, (D series) use 240cc injectors but I don't know the impedance so you may have to use a resistor box. Just pick up an set of injectors from ebay, junkyard, or auto parts stores for 85-87 CRX Si or 86-87 Civic Si. Or try Redpepperracing.com. Tons of stuff floating round there. Are the injectors clogged, seized or leaking? I made a cleaning jig to clean my own injectors, and seems to work well, so far 2 years no leaks or sticking.
Old Dec 22, 2008 | 03:49 PM
allgo88's Avatar
if you want help *** hat post in the right section.
Old Dec 24, 2008 | 05:44 PM
85ZC's Avatar
Banned
Was this thread moved? Because if it was that's fine. If it was posted here it's in the right place. Classic Honda is pre 88, according to Honda-Tech. That said, being a 87 and having a early D15 which is a EW version, not real D-series, his question is in the right place. Specifically because the injectors have a different impedance than the newer D series.
Old Dec 24, 2008 | 06:06 PM
allgo88's Avatar
it was moved.
tyvtec23
Nov 11, 2011 05:37 PM
98tegLSvtec
Mar 11, 2011 01:03 PM
2slowCivic
May 6, 2006 08:31 PM
darkd1gt
Apr 28, 2004 06:51 PM
that_guy
Sep 19, 2003 09:31 PM
