1987 Si hatchback INJECTOR Question
My homie has a 1987 Si Hatchback with 2 bad injectors (keep in mind it's a MPFI, not Dual Point). I wanted to know the CC's of the injectors so I can source him a new set from the junkyard. Are they the same as the OBD0 Da's (I think they're 240ccs)? Are they 180ccs like the Non-Vtec Sohcs? Let me KNOW what's up if U KNOW (absolutely).
Thanks
Thanks
Re: 1987 Si hatchback INJECTOR Question
Post a wanted ad here...good luck..
http://www.redpepperracing.com/forum...hp?showforum=7
Did I ask if it was in the wrong section? No dumb****, thanks for absolutely NOTHING.
Thanks for the help but I can source the injectors myself I just need to know the CCs.
Banned
The 85 - 87 CRX/Civic Si uses 195cc injectors. The 240cc injector from a 86-89 Integra have been used before in some applications, but I hear this causes it to be rich, even using the 86-87 Integra ECU. I beleive the 88+ Civics, (D series) use 240cc injectors but I don't know the impedance so you may have to use a resistor box. Just pick up an set of injectors from ebay, junkyard, or auto parts stores for 85-87 CRX Si or 86-87 Civic Si. Or try Redpepperracing.com. Tons of stuff floating round there. Are the injectors clogged, seized or leaking? I made a cleaning jig to clean my own injectors, and seems to work well, so far 2 years no leaks or sticking.
Banned
Was this thread moved? Because if it was that's fine. If it was posted here it's in the right place. Classic Honda is pre 88, according to Honda-Tech. That said, being a 87 and having a early D15 which is a EW version, not real D-series, his question is in the right place. Specifically because the injectors have a different impedance than the newer D series.
