Baro Sensor? Barometric pressure
Old Dec 21, 2008 | 02:21 PM
1 Fly SI's Avatar
Default Baro Sensor? Barometric pressure
I got a code p1106 in my 98 civic last night. The car is totally stock. I found that they said it is inside the ecu, but where exactly? I need a picture of it so I can change it.
TIA
Old Dec 21, 2008 | 03:24 PM
gsrhatch2356's Avatar
Default Re: Baro Sensor? Barometric pressure
just get a new ecu, thats all you can do to fix it
Old Dec 21, 2008 | 05:24 PM
z6hatchboy's Avatar
yeah, you need another ecu, they dont just sell the barometer because its soldered onto the ecu curcuit board
Old Dec 21, 2008 | 06:14 PM
1 Fly SI's Avatar
I am aware that it is soldered in. I have a couple extra junk ecu's just need to know what it looks like. TIA
Old Dec 22, 2008 | 05:45 AM
1 Fly SI's Avatar
ttt
Old Dec 23, 2008 | 09:17 AM
1 Fly SI's Avatar
Old Dec 23, 2008 | 09:58 AM
BryanM.'s Avatar
Resident Gearhead
Pretty sure you can't replace the BARO...
Old Mar 17, 2009 | 07:55 AM
7rrivera7's Avatar
It's the rectangular piece to the right of the 28 pin socket on chipped ECUs.
Old Dec 7, 2009 | 06:06 PM
STG3PWR's Avatar
so once you get p1106 code then you automatically need a new ecu? yikes! :O
Old Dec 7, 2009 | 06:33 PM
low_n_loud_civic's Avatar
Yes...
Old Dec 7, 2009 | 06:59 PM
thumper64's Avatar
Then try to fix it. If it's blown and you have other blown ECUs, then what do you have to lose?
Old Dec 8, 2009 | 03:14 PM
BryanM.'s Avatar
Resident Gearhead
Agreed it's worth a shot in that case, but I've been told a new ECU is the only fix.
Year old thread ftw.
Old Jun 5, 2013 | 09:45 PM
raulpuig51's Avatar
need help code 2228 barometric pressure sensor 05 civic ex I change 5 ECU
one work good the transmission, but ac no work and temp engine gage,
other ECU transmission shift bad but AC work I need choose transmission or AC
Old Jun 5, 2013 | 10:53 PM
jbpnoman's Avatar
You're in the wrong section. Don't bump a 4 year old thread. Make your own in the CORRECT section.
cornfed
May 23, 2016 06:29 PM
rjmteggy
Apr 16, 2015 10:19 PM
Hgoku10
Aug 4, 2009 09:05 AM
crxhf19
Sep 13, 2005 04:46 PM
ekx4
Aug 31, 2005 11:49 PM
