N/A help
Old Dec 20, 2008 | 02:40 PM
callmetree19's Avatar
Default N/A help
i got a new b16a and i'm about to build the head. i'm going to use supertech in/ex vavles that are the stock size. i'm about using exospeed stage 2 valve train good for 9500 to 10000 rpm. but i dont know what cam i should go with. i was thinking about the skunk2 pro stg.2 cam. with the stock 10:1 compression can i run that cam? if not what cam would be good for this set up?
Old Dec 20, 2008 | 02:45 PM
SOHC_4dr's Avatar
those cams will be just fine as long as your using stronger valve springs so it'll resist float at high rpm's.
Old Dec 20, 2008 | 02:49 PM
yeah. i'm doing all new parts in the head. i was just unsure about the cams to run. how long to you think i can run on the before i get the car tuned?
Old Dec 20, 2008 | 02:50 PM
kgibson16's Avatar
skunk pro 2's are difficult to dial in when installing. degreeing the cams might be a good idea if u use those and these cams might be a bit much on a b16a.
no interest in tuner stage 1 or 2's? bigger is not always better.
Old Dec 20, 2008 | 06:02 PM
i was going to go with a stage 1 or 2 tuner but i started thing about the head work.. and hey go big or go home lol
cleanep3
Jun 15, 2010 06:12 AM
IamVtec
Jul 6, 2009 06:01 PM
rdwaldo
Jan 30, 2007 07:24 PM
Firestarter
Oct 3, 2005 07:21 PM
EG_Type R
10
Feb 11, 2004 04:52 PM
