how do you remove alternator belt?
Old Dec 20, 2008 | 09:29 AM
t_mac's Avatar
Default how do you remove alternator belt?
I got my alternator out but I think I should replace the belt while I'm at it. I don't see how it could possibly come off without removing the other belt there...
any suggestions?
Old Dec 20, 2008 | 09:31 AM
BiggieBert's Avatar
Loved
Community Favorite
Take the other belt off. This thread is worthless
Old Dec 20, 2008 | 09:40 AM
t_mac's Avatar
How do I do that?
Old Dec 20, 2008 | 11:46 AM
t_mac's Avatar
Bump
Old Dec 20, 2008 | 01:03 PM
t_mac's Avatar
from looking at the service manual I'm under the impression that the alternator belt is the third one in so I guess to install a new one I'm going to have to remove the P/S and A/C belts to access the alternator belt.
So my question is can I loosen the crankshaft pulley and slip the belts off that way?
And also where (can I get) and what kind of tool can I use to measure so I have the proper belt deflection and tension?
Old Dec 20, 2008 | 01:22 PM
al9955's Avatar
nope the best way is to loosen the adjuster bolts on both the p/s pump and the alt, sliding both towards the engine should allow enough movement to slip both belts off
al9955
Old Dec 20, 2008 | 04:15 PM
BryanM.'s Avatar
Resident Gearhead
Originally Posted by Onsite EJ8
if you loosen the crankshaft you will change the timing
F*uckin' sig'd
Old Dec 20, 2008 | 06:59 PM
ten2doyle102's Avatar
fail.....
Old Dec 20, 2008 | 07:01 PM
I never use a tool to do that. I believe that if you can push the belt more than 1/4", its not tight enough. Obviously, if you can even push it, it too tight. It's not that difficult.
Old Dec 20, 2008 | 10:58 PM
Mrmatt3465's Avatar
I am high and I still caught that...
EDIT
No matter how many times I tried to word this post to be helpful I feel like I made no sense.
Old Dec 21, 2008 | 08:29 AM
alphalanos's Avatar
Default Re: how do you remove alternator belt?
Yes you have to remove PS and AC to get the alt. belt off. Its easy the PS has a bolt that keeps it in place, just loosen that and tap the PS pump lightly to move it and slip the belt off. AC you must loosen the tensioner enough to get the belt off. Then alt also has a bolt keeping it tight near the top, loosen that and its off. Replace all the belts while youre in there. Also check the pullies for noise and loseness/ roughness.
Old Dec 21, 2008 | 11:48 AM
t_mac's Avatar
You guys usually torque all your bolts back on?
Old Dec 21, 2008 | 11:51 AM
Topdawgg's Avatar
no
Old Dec 21, 2008 | 12:17 PM
burningrex's Avatar
Here you go man here is the service manual... hope it helps
http://www.spoonhonda.com/SearchResu...9&Redirected=Y
Old Dec 21, 2008 | 01:20 PM
bmxmacdaddy's Avatar
wow...
southernSCHEME
22
Jun 28, 2011 06:26 PM
dotay
Dec 30, 2006 01:35 PM
failed
Sep 4, 2005 05:59 AM
Kato7997
Feb 23, 2003 11:23 AM
babyviper97
Jan 27, 2003 01:17 PM
