Swap Question- Wiring Harness
I'm about to pick up a complete '96 LS swap minus transmission for my '95 EX.
Will the wiring harness that comes with the LS snap directly into all of the connections on the civic or will I have to modify anything?
I'm going to use my P28 (already chipped from when the civic was turbocharged) & I'm getting all of the motor mounts.
For the swap I need the rear trans mount & the left motor mount from the B series, right?
Thanks for the help.
Yes, plus the lower transmission bracket for the torque mount if you're going to run torque mounts, you need to reuse the rubber civic mount though, same goes for the A/C bracket on the driver's side.
Thanks a lot.
That's good news on the torque mounts. Means I can keep my ES bushings in there.
I imagine it'll be just like swapping from one D16 to another, just a couple of extra steps. And a lot harder since I don't have the garage, tools, & man power I had during the last swap.
esurds
Jun 25, 2009 06:03 AM
xaine
16
Apr 11, 2009 08:35 PM
yellaboi
Aug 9, 2003 10:34 AM
