tail ligts and headlights need electrical fixing
Old Dec 19, 2008 | 06:22 PM
ibr_adam09's Avatar
Default tail ligts and headlights need electrical fixing
well as some of ya know i got my car going again after like 3 months of sitting at my auto shop
everything is back together and in check
my problems now are my headlights and taillights
taillights--- night brake and foot brake work , my L/R signal bulbs don't turn on but they are not blown still in good condition
my headlights-- everything was working great , but when i was working on my driver side low beam light adjustment, the light suddenly turned really low dimmed ( the passenger side was still fine), now when i turn on my high beams the driver side is also dimmed and the passenger side is still just fine.
i checked all the grounds and cable connectors for front and back lights, they are all fine too.
i need this fixed !!!
Old Dec 19, 2008 | 06:35 PM
Paul-R's Avatar
it is always best to change all bulbs when working on the lights,,, 2nd check fuses,, and maybe there is a pinch in the wires replace all light connectors that is the best way to start .
Old Dec 20, 2008 | 08:40 AM
Duane_in_Japan's Avatar
Do a voltage drop test and find the problem.
Old Jan 4, 2009 | 03:36 PM
hitemup1435@yahoo.com's Avatar
Default Re: tail ligts and headlights need electrical fixing
have the same problem except my front headlights come on and my back lights dont work my brake light also works ???
Old Jan 5, 2009 | 02:39 PM
Brake lights work, tail lights do not, this is usually a tail lamp fuse blown, you may have a wire problem or a connector issue, dont forget that all of the tail lights may be blown out too.
JDMin206
Lighting
Jan 10, 2012 05:28 PM
lxdriver
Lighting
Aug 13, 2011 05:39 PM
92VXeg
Sep 2, 2008 05:28 PM
PreludeGuy27
Dec 3, 2005 07:46 PM
ep3hatchblack
Mar 20, 2004 12:14 AM
