Cant get crank gear off help!!
Old Dec 19, 2008 | 10:32 AM
hondachris1994's Avatar
Default Cant get crank gear off help!!
Ive tried to pry it from both sides and it wont budge. I even broke 1 of the ears off on the spacer part by accident. Shouldnt it just slide off without any issues? Any help is appreciated. Pic of the gear is below
Old Dec 19, 2008 | 12:04 PM
bump for some help
Old Dec 19, 2008 | 12:59 PM
Yeah I guess I could try some liquid wrench on it then try to pry slowly. Ive tried a pry bar on each side and it still wouldnt budge. Hopefullt the liquid wrench will do the job
Old Dec 19, 2008 | 01:05 PM
BiggieBert's Avatar
Loved
Community Favorite
Theres nothing in the key-way blockin? kinda looks like there is in the pic.
Old Dec 19, 2008 | 01:10 PM
yes there is a key way, its supposed to b there just like the key way on the crank pulley. That gear should slide off there but for some reason its stuck. The block does have some surface rust from bein outside. Its getting hot tanked as soon as I can get that gear off so I can get the crank out
Old Dec 19, 2008 | 04:17 PM
z6hatchboy's Avatar
either pry on both sides at the same time, or get a gear puller. It should come off fairly easy though
Old Dec 20, 2008 | 08:32 AM
Ive tried PB blaster and still nothing, but it has moved a lil, I guess ill just keep spraying and keep wiggling with the 2 prybars until it comes off
Old Dec 20, 2008 | 03:04 PM
Finally got it, after the PB sat for about 30 mins it came rt off
Sam1am26
Dec 30, 2019 09:50 AM
preludeNApower
Dec 4, 2012 05:52 PM
shaggyrufener
Aug 21, 2012 07:54 PM
BigPlansNoMoney
Sep 25, 2007 12:53 PM
Prelude Vtec 23
Apr 16, 2002 09:57 PM
