hid foglight problem
Old Dec 19, 2008 | 07:49 AM
immajackuup's Avatar
Default hid foglight problem
My foglight work but one side tend to flicker than shut off and the other side stay on.
is like not getting enough power or something.
how could i fix this?
Old Dec 19, 2008 | 09:03 AM
z6hatchboy's Avatar
might be the ballast box
Old Dec 19, 2008 | 09:11 AM
JDM_SOHC's Avatar
what fogs do u have HID's in..??
Old Dec 19, 2008 | 09:20 AM
they are in good working order.
regular h3bulb
also my fuse is a 30amp that came stander with my foglight
Old Dec 19, 2008 | 09:45 AM
well i just found out that the only way for both of them to turn on is to unplug and replug the foglight.
but if i leave them both plug in and turn on with the switch only one side will work and from there i have to unplug and replug one of the foglight inorder to work.
so what could be the problem?
for the people that have hid foglight please help me!!!
Old Dec 19, 2008 | 10:15 AM
Crx Jimmy's Avatar
your wire isn't a thick enough gauge. Run a separate relay for each light and run the ground from the ballast directly to the cars sheetmetal.
Old Dec 19, 2008 | 10:27 AM
I got one thick wires with relay that i'm not using.
came off my hid headlamp,I just plug that hid to the stock plug.
also is relay is just a relay??
I really don't know much about relay.
Old Dec 19, 2008 | 10:49 AM
yes!!!! they're working now!!!
Because i need the motor to be running inorder for both of them to be on.
guessing it need a lot of juice to make them work.
Old Dec 19, 2008 | 11:40 AM
Warhawk's Avatar
I kind of had this problem but just with HID's in my regular housings. It is an 00 4dr civic dx. My battery was always a little weak and a few months ago I replaced it and never had the problem again. I think its because when you fire them up they require a good steady amount of electricity and if your battery is worn out it might cause some problems.
Old Dec 19, 2008 | 01:19 PM
yeah that maybe is why.
but i'm so happy that it work now.
_EF9
Lighting
Nov 25, 2012 05:58 PM
codenamezero
Audio / Security / Video
Jul 26, 2007 06:34 PM
Magaton00si
Mar 22, 2006 10:31 PM
b18bEG
30
Dec 13, 2004 05:26 PM
b16hybridsol
Sep 25, 2004 01:45 AM
