91 HF Bad Partial Throttle Response - Test TPS without removal?
Old Dec 19, 2008 | 03:34 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default 91 HF Bad Partial Throttle Response - Test TPS without removal?
The car idles smoothly, and revs correctly in neutral/not in gear. (all HFs are 5spd)
Car rides smoothly, and correctly, at speeds 0 through +60mph (have not gone faster than this on local roads, speed limit is 50mph).
Car rides fine when accelerating, or coasting, in gear.
However, at partial throttle, I typically get a good shaking. Both front tie-rod ends needed to be replaced, and I did. No alignment yet, I counted threads when replacing the tie rod ends. New tires. New o2 sensor (needed it)
Car has 109k on it. All original.
I read the TPS could be the problem, but it revs cleanly, no problems, could it still be the TPS? I do not have a voltmeter to measure with. I do have a replacement TPS to install (though I am still waiting for the gasket).
I also have a 90HF with 139k on it if I need to swap/test parts.
Input welcome!
Old Dec 19, 2008 | 05:46 AM
addicted2speed's Avatar
I am having the same exact problem with my DX. As far as the TPS goes I wouldn't think that would be it, but it could be. My DX is a 90 with only 52k on it, all original with a gay auto tranny (for $600!). But I am with phoenix, input welcome!
Old Dec 19, 2008 | 06:24 AM
Gotrek's Avatar
Go buy a voltmeter dude you can find them fairly cheap and it's a tool no modern mechanic should be without.
I fixed my TPS in no time with a multimeter
Old Dec 19, 2008 | 10:54 AM
The TPS required adjustment?
Old Dec 19, 2008 | 12:29 PM
Slystone's Avatar
in JDM model engine the TPS is not weldin but here in US/CDN is all ready ajust and weldin! if you want to ajust TPS sensor you have to drill out the 2 rivet and get a ohm metter!
Old Dec 19, 2008 | 01:15 PM
I thought just slice a slot into the head of each and turn like a screw to remove, then replace it with bolts. Adjustment, on the otherhand, how is it done, and what are the specs? =(
Old Jan 19, 2009 | 06:59 PM
Default Re: 91 HF Bad Partial Throttle Response - Test TPS without removal?
What else can I test besides tps?
Old Jan 19, 2009 | 08:13 PM
slimjimming6688's Avatar
swap it out with another
Old Jan 19, 2009 | 09:19 PM
SOHC_4dr's Avatar
if you want details on what the sensor should read check out my sig
Old Jan 20, 2009 | 09:41 AM
Just swap out the whole throttle body? It's attached there, correct? I have a 'spare' TPS (new from Ebay), but then I read they have to be calibrated and whatnot... =(
Old Jan 20, 2009 | 09:44 AM
95f22a1's Avatar
my ek hatch did the same thing i took the injectors out and cleaned the filters on them and didnt have the problem again.
Old Jan 20, 2009 | 10:37 AM
Neat! It does feel like a fuel delivery problem (but only at partial throttle)... hmm... I wonder about sending the injectors out, or running some super fuel injector clear through it (sea foam in the gas tank?)
Thanks for the idea!
thapimpfromchi
31
Jun 1, 2011 08:37 AM
mouab18c1
Engine Management and Tuning
18
Jun 3, 2010 10:57 AM
phoenix_iii
18
Mar 13, 2009 12:34 PM
JdmHondaBitch
Feb 18, 2008 07:53 PM
Boost3d22
Mar 17, 2005 12:48 PM
