Ignition coil? Gas.. Help!
Old Dec 18, 2008 | 07:11 PM
vlc92189's Avatar
Default Ignition coil? Gas.. Help!
so i was driving home and my car just shut off.. it will crank like it wants to start. and i am pretty sure i have enoguh gas ( going to fill up now ) but this happened in my old car as well.. car died in the middle of a rain storm and i thought i hyrdolocked my car but it was the igntion coil.
now my question is, i have a 94 jdm b16 and i was wondering what motor or car would i buy the igniriton coil for? the 99 si?
also, does this sound relevant to my problem? thanks guys n girlss.
Old Dec 18, 2008 | 07:18 PM
Unseen Racer's Avatar
its the ignition coil
my car did the EXACT same thing.
i had it towed then the next day i checked everything.
timing, fuel filter, fuel pump etc.
then i was stumped. i thought "hmmm the igintion coil send sparks and its not starting. i think ill check it" and sure enough it was that.
i changed it and vuala! it worked GREAT!
Old Dec 18, 2008 | 07:26 PM
94EG8's Avatar
Seagull Management
Any OBD1 or OBD2 D or B-series coil will work. I've personally used D15B7 coils in B16A distrbutors before.
Old Dec 18, 2008 | 10:19 PM
bmoua's Avatar
i went through the exact same thing bro...haha
i'm sure almost any b-series ignition coil should work OP, i would look for a b-series vtec dizzy though. I swapped in a obd1 eg/ej (single cam) ignition coil into my obd2b ej and it runs fine.
JDMCIVIC919
Nov 17, 2011 03:40 PM
nanagsr
Jun 24, 2009 07:04 PM
95blackEG
Dec 24, 2008 07:59 PM
RoaringTurtle
Jan 30, 2002 10:50 PM
