Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
speedometer sticking
Old Dec 18, 2008 | 06:54 PM
integ_lude's Avatar
Default speedometer sticking
Hey guys I just bought my wife a 2001 Honda Civic EX for a cheap price of $5100 out the door which I was at first amazed by it has only 103,000 miles.
I was driving down the road after I bought it for like an hour and of course i never look at the speed I drive because I am used to certain speeds. I noticed the speedometer would not move for a while. It would stick at 20, then jump to 40, then 60, and it wouldnt go to 90 even though I knew I was going that fast. What should I do? I know this is the best source and I just got home. Could the person messed with the miles like turning them back?
Thanks guys
-Logan
Old Dec 18, 2008 | 07:08 PM
katzenjammer84's Avatar
Could need a new wheel speed sensor.
Old Dec 18, 2008 | 07:14 PM
integ_lude's Avatar
are those expensive, where do I pick one up?
Old Dec 18, 2008 | 07:23 PM
It's just an idea, I would diagnose it properly before you begin replacing random parts. The cluster itself could just be due for replacement.
It'd be a great time for an 03-05 upgrade.
Old Dec 18, 2008 | 09:17 PM
wickedbautista's Avatar
this was posted by RHCP0801 member on 7thgenhonda.com. try and see if it helps also try unplugging your battery for atleast 20 min ans see if works
"try doing a cluster reset, not sure if it will work but mine as well try
try this
1. push/hold the trip button.
2. turn the lighting switch on.
3. turn the ignition switch on.
4. (within 5 seconds) turn the lighting switch OFF, then ON, and OFF again.
5. (within 5 seconds) release the trip button
6. push and release the button 4 times repeatedly.
this starts the gauge cluster self diagnostics...
the beeper will sound
the lights will flash
the LCD will flash
the needles will sweep "
Old Dec 19, 2008 | 05:20 AM
integ_lude's Avatar
try this
the LCD will flash
Awesome I will try this on my lunch break today.
Update: This is what I noticed this morning. I started the car up in the cold, drove it for 10-15 minutes and the speedo worked fine. After the 15 minutes it started to freeze at 20, then 40, then 60, it would jump to each speed instead of steadily moving to it.
I am going to go look at that site too, thanks!
-Logan
Old Dec 19, 2008 | 05:40 AM
Kongo69's Avatar
Dont look over that this could be electrical probs. low voltage will cause Checkengine lights and codes to be thrown such as low voltage in o2's. speed sensor relay.
Test the alt and the batt.
Old Dec 19, 2008 | 10:24 AM
integ_lude's Avatar
So I tried the steps you posted (besides the ones at that site) and I did not get any chirps or light flashses, I even tried 5-6 times in order. I drove the car for 10 minutes, the speedo worked fine until the car warmed up then it started to skip from 20 to 40 to 60, it only happens when the car is warm. I am going to try the steps on that other website tonight when I have tools to take off the battery terminals.
-Logan
Old Dec 19, 2008 | 12:02 PM
Post
-Logan
if they/one does not sweep properly, replace the cluster.
or also check the speed sensor
Old Dec 19, 2008 | 08:06 PM
integ_lude's Avatar
Ok its resolved. Here is what I did. I followed all the steps that were posted, even the ones on the other website. Those steps did not fix the problem since I knew the gauge was sticking and nothing was resolving the problem I said screw it and took out the speedometer (5 screws total). Once I got the speedometer out I started taking it apart. I moved each needle on the gas gauge, RPM, Temp, and all went back to their original positions fine. The MPH did not work correctly at first it did but then it started sticking when going back to the original spot. It was like a clock problem I had in the past so I said hell let me tinker with it, what can hurt right?
So I pulled on it, twisted it, etc... I then found out if I pressed on the back of the entire pod it would work because it was lifting the needle up just enough, it was not bent it just wouldnt work unless I put preasure on the back. Once I pushed hard enough it started working on its own. I put it all back together and it worked all night. Very weird but I am wondering if someone messed with it and didnt put the parts back together perfectly.
Anyways there was no electrical problem, etc... As long as you take your time in tinker with it comparing to the other gauges you should be able to get it working
-Thanks guys for all your support you rock!!!
-Logan
Old Dec 19, 2008 | 09:36 PM
well I am glad your problem is solved
Old Dec 20, 2008 | 10:59 AM
Kongo69's Avatar
Well done my man.
inhot
Jul 13, 2006 04:02 PM
imadigitalgod
Oct 31, 2004 02:57 AM
mingbling
Jul 24, 2004 11:18 AM
Civichatch972
Oct 27, 2003 03:15 PM
PSU
May 11, 2002 10:30 PM
