where is the idle air control valve (b16a)?, and How do I clean or replace it?
Old Dec 18, 2008 | 04:54 PM
touandcim's Avatar
Default where is the idle air control valve (b16a)?, and How do I clean or replace it?
I think my cars idle air control valve is sticky or not working very well. the motor's a b16a. anyone have any idea on how i could clean it, or replace it? any info would help tons, cuz i need my car working to be able to go to school. thanks in advance.
Old Dec 18, 2008 | 05:17 PM
boostedcivicsir's Avatar
Mr. Badwrench
on the back of the intake, has 2 bolts, 2 wire connector, and 2 coolant hoses.
Old Dec 18, 2008 | 06:13 PM
touandcim's Avatar
thanks. but u know how to clean it?
Old Dec 18, 2008 | 06:16 PM
lee0149's Avatar
i dont know how to help but one thing is true about ht they really dont want to help people. once i asked about a code problem had no help. google was better.
from what i know about it you cant clean it.
Old Dec 18, 2008 | 06:20 PM
T3KNiQe's Avatar
Soak the damn thing in & out & all over in carb cleaner, then put back on throttle body.
Old Dec 18, 2008 | 06:23 PM
96electronH's Avatar
^^^^gotta talk to the right people just pull the iacv off and spray it down with some air intake cleaner like brake clean, anything that will dissolve like denatured alcohol. i did it to mine and its fine. clean out the port that goes into the manifold to.
Old Dec 18, 2008 | 06:24 PM
touandcim's Avatar
thanks everyone. i'll try it and see what happens
Wakes4Fun's Avatar
Wow, your retarded. Use the damn search button and YES you can clean a IAC valve.
Take it off, then spray it down with brake parts cleaner. Then clean it inside and out with a stiff bristle toothbrush.
Old Dec 18, 2008 | 06:32 PM
^^^well said
Old Dec 18, 2008 | 06:45 PM
touandcim's Avatar
yeah. i try searching usually. didn't bother to do it this time, cuz i didn't feel like sorting through all the other ****.
jdmstyleEJ6
May 19, 2011 06:51 AM
JOS-EM1
Oct 16, 2010 08:52 AM
paul23
Dec 23, 2009 03:39 AM
thunderboy
Sep 2, 2008 03:41 PM
slo_ej8
May 21, 2008 08:44 PM
