Oil out exhaust...
Old Dec 17, 2008 | 09:56 PM
curtiss_robinson's Avatar
Default Oil out exhaust...
So i fire up my new motor after its rebuild (my first rebuild)...the car starts up fine...idle is off but acceptable for now. After about 5 mins of the car running i notice that oil is dripping out of my exhaust. I have hedman hedders so the oil is not coming out of the tail end...its coming out at the flange where it turns from 4 pipe to 2 pipe...I pulled off the headers and every cylinder was letting oil out. I just had a valve job done...so i know its not the valve seals. I put new piston rings in so i now its not the rings. So how else could so much oil get inside? Could it be the angle of the new piston rings were put in is wrong? Im totally stumped on this...i need to fix the problem soon...being that the car is now going to be my daily...I need help. What do you guys think is causing this???? feel free to ask questions. Thanks.
Old Dec 17, 2008 | 09:58 PM
speed_demon018's Avatar
did you get the right size piston rings?
Old Dec 17, 2008 | 10:10 PM
Im pretty sure i did...theres a small chance that the previous owner had the cylinder bored a little but to my knowledge the cylinders are not oversized...Know of any way to check if they are oversized?
Old Dec 17, 2008 | 10:12 PM
measure the cylinders with a dial, but make sure you know what the stock specs are for the cylinders..
Old Dec 17, 2008 | 10:15 PM
Ill check it out tommorow....I appreciate the quick help.
Old Dec 18, 2008 | 05:27 AM
93LsVx's Avatar
i had oil comming out of cylinder one, and it ended up being a valve stem seal.
Old Jan 11, 2009 | 06:45 PM
Default Re: Oil out exhaust...
I finally fixed the problem! it was the rings...my bottom oil ring was not gapped correctly...and i did get the head bolt fixed so im sure that helped to. Thanks for the help.
FireInTheHead
Nov 4, 2014 04:15 PM
Hondata27
Dec 5, 2011 10:55 AM
SD99GSR
Jul 24, 2007 03:36 PM
Jorsher
Sep 7, 2006 06:05 PM
LShatchie
Aug 4, 2005 02:43 PM
