CLutch help
Old Dec 17, 2008 | 05:11 PM
speed_demon018's Avatar
Default CLutch help
I need instructions on how to change the clutch in my 94 ex. if someone has a website or has done this them selfs let me know
Old Dec 17, 2008 | 05:32 PM
boostedcivicsir's Avatar
Mr. Badwrench
my boss always told me, if its in the way unbolt it.
basically you need to get the air box out, starter out, undo the slave cylinder but dont take off the hydraulic line, get under it, wheels off, axles loose, separate the lower ball joint, axles out.
shifter linkage, drain it, bell housing bolts, drop the trans.
somewhere in the begining undo vss, and reverse switch.
remove the clutch, 6 12mm bolts, and if you are surfacing the flywheel, you will need a 17mm 12 point socket.
install in reverse order.
it can be done but if it is your first and not mecanically inclined, enlist a friend that is.
Last edited by boostedcivicsir; Dec 17, 2008 at 05:33 PM. Reason: spelling ownz me
Old Dec 17, 2008 | 05:35 PM
i am very mechanically inclined but my thing is i have no place to do it and there is snow on the ground and i dont have money to pay someone to do it. and how do you hold up the motor to drop the transaxle
Old Dec 17, 2008 | 05:56 PM
Mr. Badwrench
get the car on jack stands, and use the jack to hold the engine up.
is the loot you are going to save, worth the time aggro, and being cold as *****? to have it done in a shop? it may cost a little, but in the long run, your down time and possibility if getting sick, hell i wouldnt do it.
Old Dec 17, 2008 | 06:10 PM
well i dont have a job so actually getting it done in a shop might be alittle hard to do, i can still drive the car the clutch is not completely out so i guess i could wait til i find a job
Old Dec 17, 2008 | 07:17 PM
jdmsinglecamdelsol's Avatar
lol sorry but if its ur first time and ur mechanically inclined good luck pay to have it done its only around 300-400
Old Dec 17, 2008 | 07:20 PM
yeah 300-400 i dont have but i have down alot of things with cars even motor work i just have never changed a clutch
Old Dec 17, 2008 | 07:58 PM
zeplin's Avatar
A mechanically inclined individual could do this job in 2-3 hours, depending on how many little problems you run into. It's really quite simple and boostedcivic explained it perfectly.
Since there's snow outside, could you perhaps find a buddy or someone who has a garage you could borrow for a day? Or even a car porch..just some type of structure to block the wind and you'd be golden.
Old Dec 17, 2008 | 08:00 PM
yeah but dont know anyone that would let me use a garage my parents have one i just need to clean the Sh@t out of it and i would be good.
Old Dec 17, 2008 | 08:17 PM
niceprelude's Avatar
how does it feel,when the clutch is need to change
Old Dec 17, 2008 | 08:19 PM
94EG8's Avatar
Seagull Management
The only thing I'll warn you about is that you need to remove both axles. I've seen guys try to cheat and only take out the passengers side, you can get the tranny off, but it just wont seem to line up properly to go back on. I literally spent 2 or 3 hours trying, removed axle, no problem.
well if you let off the pedle and your vehicle dont move then it would be going out... what is your clutch doing
Old Dec 17, 2008 | 08:31 PM
starting in first gear,its a little slipping not smooth and erratic and top of the clutch is a little loose
street_ride14
Apr 29, 2018 04:07 PM
Jdm_Josh915
Aug 4, 2009 05:33 AM
rick_rabies
26
Mar 12, 2009 07:49 AM
lsdDrifter
Dec 2, 2008 06:43 PM
