Need help with paint streaks
Old Dec 17, 2008 | 03:18 PM
JDM3STAGEVTEC's Avatar
Default Need help with paint streaks
ok so im currently painting my car, i like the primer color alot so i plan on keeping it then clear coating it (ive seen it done before) the primer is Duplicolor's "Sandable primer" By wet sanding it, will it remove the streaks and make it all even? Thanks, MUCH appreciated
Old Dec 17, 2008 | 03:20 PM
1LowSol's Avatar
Yes.
Old Dec 17, 2008 | 03:23 PM
You just saved my life, THANKS!
Old Dec 17, 2008 | 03:31 PM
1LowSol's Avatar
Np, Just take your time while your wet sanding don't try to rush things.
Old Dec 17, 2008 | 03:35 PM
ok, whats a good number to start with? I was thinking, 600 grit, then 1000, then 1200, then 1500?
Old Dec 17, 2008 | 03:41 PM
eg2ekevin's Avatar
start with the 1000 unless your paint uh primer is really jacked up
Old Dec 17, 2008 | 03:43 PM
1LowSol's Avatar
You really don't need to do all that, Try 800 and see how it looks.
Old Dec 17, 2008 | 04:44 PM
there are some parts where it looks like little sand bits, hard to explain but ill try the 800!
IROCKCIVICS
Paint and Body
10
Feb 2, 2008 08:36 PM
Fighterinsnatch
Mar 9, 2007 01:08 PM
NazVil86
Mar 7, 2007 12:56 PM
Full Race A6
May 30, 2004 09:53 PM
IdotheSHOCKER
21
Jun 26, 2002 02:09 PM
