94 civic door lock
Old Dec 17, 2008 | 02:18 PM
b18 hatch mike's Avatar
Icon2 94 civic door lock
my driver door you can lock it and unlock it fine from inside but you can from outside any ideas
Old Dec 17, 2008 | 02:24 PM
uzi1's Avatar
try using rem oil in the tumbler and work it with a key, if not you may need the tumbler for the door. the rem oil can sometimes work miracles.
Old Dec 17, 2008 | 02:54 PM
so just sray it in the key hole lol ?
Old Dec 17, 2008 | 02:56 PM
1LowSol's Avatar
Yeah and work it in with the key.
Old Dec 17, 2008 | 03:09 PM
honda.lioness's Avatar
Lock-Ease (liquid graphite lubricant) is effective often in fixing situations like this. Available at Wal-Mart and the like. Either the key or the lock plates in the door's lock's cylinder wear; more likely the key. Follow the bottle's directions. Otherwise, disassemble the door and lock cylinder, clean thoroughly, and get a new key but only from the dealer. These sites can help with the lock disassembly:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-fixing-doorlocks-open-any-key-2237857/
http://www.zeebuck.com/bimmers/tech/...doorlocks.html
If the tiny lock plates inside the cylinder look worn, go to the junkyard and pick up four or so lock cylinders and cannibalize for the correct lock plates.
Old Dec 17, 2008 | 06:31 PM
uzi1's Avatar
rem oil has been awesome for me. its cheap and you can get it at any gun stores. ive used it for years. just spray it in with the straw in the tumbler, spray it in, then work the tumbler with key
Old Dec 18, 2008 | 06:48 AM
i got tons of rem oil lol i am about to try it i hopr it works
triple beam
Jan 13, 2019 04:40 AM
ayau
Feb 10, 2013 01:45 AM
Valvos
17
Jan 18, 2013 08:00 PM
gezulu
Honda Civic (2001 - 2005)
Sep 13, 2008 04:02 PM
matt j
Jun 1, 2003 08:27 PM
