Speedometer not working
If you Do have any associated Warning lamps staring back at you (like either the "Check Engine" or a flashing D4 (auto only) it would (most likely be the VSS (Vehicle Speed Sensor)
P
AHHHH!!!!! I gotcha. Well there is no lights lit except for the ABS. (still trying to figure that one out. But Im not sure if the check engine light is even working. Could have been removed or just burned out. Hmmmmm.... looks like either way, taking apart the dash to get at the cluster is a must!
I hope its just a loose connection.
If its the speedo what goes wrong with them?
This car needs sooooo much work. I already replaced the wiring harness for the headlights, got a new windshield wiper fluid pump, replaced all the tires, put in a new battery, replaced the wipers, painted the rear quarter panels with anti-rust stuff and of course gave it a oil change.
It still needs:
I hope its just a loose connection. If its the speedo what goes wrong with them?
It still needs:
- passenger airbag
- ABS fixed (no idea whats wrong with it)
- Speedo fixed (no clue either)
- dash lights replaced
- glass pack muffler replaced with normal one
- both tail lights replaced with stock ones
Check that there's sufficient brake fluid in the Master Cylinder reservoir. There's a level sensor in there which trips the light if the fluid gets too low. still trying to figure that one out. But Im not sure if the check engine light is even working.
Turning the key to the run position should cycle the CEL on for confirmation that it's working
It still needs:
It still needs:
- passenger airbag
Let me know what you find.
P
