I feel stupid but....
If you have never fiddled with your shift boot or center console, there are two screws (#47) holding the shift console in place (#10). You have to remove the entire console (#9) and get at those two screws, once removed you can unscrew another two screws holding the shift boot to the console. Installing the new one takes only about 5-10mins at most.
the best way to do it without damaging anything is this-
remove the entire boot, unscrew the **** with the boot still attached, then take needle nose pliers and squeeze the clips off from under the ****, it will pop right out.
Type-Spaz
Nov 28, 2012 05:22 PM
LudemanDan
Jun 1, 2002 12:51 AM
