Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Who works at a Honda dealer?
Old Dec 16, 2008 | 01:25 PM
203_EM2's Avatar
Default Who works at a Honda dealer?
I want to change my oil in my Mugen Si, the dealer i bought it at said it was fine that it wouldnt void the warranty but as long as i had receipts for it. now my question is what receipts do i need? i will be buying a filter from honda and then just Mobil 1 from my local parts store are those the reciepts they are referrering to? or did they mean reciepts showing that i got it done? and should i also write down date and milage which i did my oil change. thanks in advance
Old Dec 16, 2008 | 01:37 PM
pd0019's Avatar
receipts would just be used to show that you purchased oil and filters. i dont know if dealerships actually look at your service record for warranty stuff, but i have taken my car in a couple of times for warranty stuff and they have never turned me down even though i do my own oil changes. i keep records of the mileage when i do oil changes (for my own records) but i have never been asked for them.
Old Dec 16, 2008 | 01:38 PM
Zeusone's Avatar
wtf. your dealer is garbage. you can have anyone change your oil as long as they do it right.
Old Dec 16, 2008 | 01:42 PM
RICO_'s Avatar
NO MERCY!
If you do the oil change yourself all you need is receipts from the auto parts store showing that you purchased the oil and filter. If you have the oil change done at a shop make sure you keep their receipt that they give you. It's a precaution dealers take to cover their end to make sure you are doing your part in terms of vehicle maintenance.
If you do the oil change yourself you don't need to write down the date and mileage. The date will obviously be printed on the receipts and as long as the intervals between purchases aren't excessive and pretty much match up to the recommended intervals for the oil changes you'll be fine.
Old Dec 16, 2008 | 01:46 PM
RICO_'s Avatar
NO MERCY!
His dealer never said he couldn't have anyone else change it. Read the post again. They basically told him to keep the receipts for the parts purchase (oil and filter). He might not have spelled it out in his post....but it's pretty much implied.....what other kind of receipts would he have if he changed the oil himself??
Old Dec 16, 2008 | 02:39 PM
Targa250R's Avatar
be professional
Under the federal Magnuson-Moss Warranty Act, it is illegal for an automobile manufacturer to void your warranty if you don't have it serviced by the dealership; they must honor the warranty as long as all recommended services have been performed. It is also illegal for them to void your warranty due to the presence of aftermarket parts, unless it can be determined that the aftermarket part caused the failure.
I wouldn't worry about saving oil recepts, but I would document all services that you perform on the vehicle. Honda provides a maintenance history book along with the rest if the vehicle documentation to keep records of services.
Old Dec 16, 2008 | 06:34 PM
203_EM2's Avatar
alright cool just wanted to make sure appreciate all the help and yea i will be doing the oil change my self at work on the lift
Old Dec 21, 2008 | 03:26 PM
racereaper7's Avatar
Default Re: Who works at a Honda dealer?
i work at a honda dealership and at our dealership they will put mobil 1 oil in your car instead of there honda oil.
Old Dec 22, 2008 | 02:46 AM
RICO_'s Avatar
NO MERCY!
Why?....it's the same engine. That pretty much sounds like a slap in the face to Honda's motor oil.
Old Dec 22, 2008 | 03:50 AM
Mechanic's Avatar
Just for info, "Honda" motor oil -- i.e., the stuff labeled "Honda Motor Oil" -- is manufactured by Exxon-Mobil and sold in N. America under a license agreement with Honda. (No mystery here, "Exxon-Mobil" is printed on the container.) It's a "good" conventional oil, and is identical to the stuff sold by Exxon-Mobil under their own label.
Old Dec 22, 2008 | 05:38 AM
Targa250R's Avatar
be professional
Very few if any Honda dealerships use actual Honda-branded oil (which, as mentioned above, is just conventional oil sourced from ExxonMobil). Most dealers have a deal to purchase bulk oil from a local distributor, be it Valvoline, Castrol, Mobil, etc.
Old Dec 22, 2008 | 12:24 PM
RICO_'s Avatar
NO MERCY!
Interesting bit of info and something I didn't know.
But my question still stands. Why would a Honda dealer put Mobil1 in a Mugen and not in an ordinary Si even though they have the exact same engine??
Old Dec 22, 2008 | 12:30 PM
Targa250R's Avatar
be professional
No idea. I was scratching my head at that comment as well because it wasn't particularly clear.
Also, to elaborate further on what I told you above: While most dealerships buy bulk oil from a local distributor in the two most common viscosities (5w-30 and 5w-20), they do still use Honda-branded oil in special circumstances, such as for hybrids that require 0w-20 oil which is unavailable from the usual sources, or with the less common 10w-30 used in S2000s.
Old Dec 22, 2008 | 03:48 PM
00GSREJ8's Avatar
also if it is a used car thats to be certified by honda and put out for sale it has to have Honda fluids and filters in it
Old Dec 22, 2008 | 05:53 PM
SOHC_4dr's Avatar
the honda dealer i worked at, our oil was made by mobile1
Old Dec 22, 2008 | 06:47 PM
allmotorek4's Avatar
yes sir thanks to i believe President Ford on January 4, 1975, pass that law ... dealer will have to go after that person who did the work and sue them ... you can have any aftermarket parts on your car as you wish. and they will still have to service it.
Old Dec 23, 2008 | 03:24 AM
Targa250R's Avatar
be professional
"Mobil 1" is not a company; it's a product brand of ExxonMobil. Chances are your dealership used conventional Mobil oil, not exclusively the "1" synthetic.
I haven't decided whether ExxonMobil's advertising is a success or a failure with the amount of people out there who can't distinguish between "Mobil" and "Mobil 1" labeling.
KFRG
Feb 8, 2010 05:56 AM
Bulli Kid
12
Apr 16, 2007 02:03 PM
EngineNoO9
Honda Motorcycles
21
Jul 31, 2006 06:10 PM
sonicrex
Jan 21, 2005 01:27 PM
Mr Boston
Apr 4, 2003 05:30 PM
