1992 Honda Accord brake problem
alrighty then I have a 1992 Honda Accord with ABS the first really cold weather of the year has just hit our door step well I go out to my car to start it and I find out that my brakes go all the way to the floor. I put some brake fluid in the resivor and the petal still goes to the floor, before this weather the brakes worked fine, does anyone at all know what is wrong with my car and how much it might cost to fix thank you and I appreicate it
Do you see any fluid on the ground under the car where there may be a leak? You may have a hole in one of you brake lines. If not, I would be looking at the master cylinder. When the seals go bad the fluid will bypass the seals.
Brake fluid absorbs water over the course of time; and when it becomes supersaturated it starts corroding things metal. things like Master and Brake cylinders, brake pipes (lines). When this corrosion gets far enough along, the seals on the cylinders' pistons can't conform to the damaged cylinder walls. Thus the loss of pedal.
You can probaly expect a range of from 100.00 to 200.00 depending on where you have it done.
P
The fresh brake fluid will temporarily swell the piston seal, but the underlying condition still exists.
Hopefully, it won't be at a criticle point when it decides to go on a sabaticle. Has the Master Cylinder ever been replaced?
P
It can onset gradually where you can grab an intermittant brake pedal by pumping the pedal, and gets progressively worst over time OR
It can fail catastrophically and not respond at all.
P
Sergey.R
Jun 23, 2015 10:32 AM
Schubs
Jul 29, 2008 03:03 PM
