Integra Injector Wiring Colors....and What is Their Order??
Old Dec 15, 2008 | 06:43 PM
95dc2teg's Avatar
Default Integra Injector Wiring Colors....and What is Their Order??
Here is the story: I had to change my head gasket. I did so and in the mean time i went ahead and bought a new Intake manifold. Well I had to cut and splice my injector wires to extend them for my new intake manifold. They are all practically the same size now. I think i might have mixed up the wires for the injectors for cyl 3 and 4. Now I searched and found this:
Injector #1 (closest to driver's side)
solid brown wire
yellow wire w/ black stripe
Injector #2
solid red wire
Injector #3
solid blue wire
Injector #4
solid yellow wire
Is this correct?? I am pretty sure i mixed up these wires because I started the car after all was said and done the car had a flashing CEL, which after searching means a bad misfire. Now will mixing up the injector wires cause a flashing CEL, misfire??? Also could starting it with this misfire damage anything?? TIA!
Old Dec 15, 2008 | 07:01 PM
95dc2teg's Avatar
anyone?
Old Dec 15, 2008 | 08:00 PM
95dc2teg's Avatar
someone has gotta know....
Old Dec 15, 2008 | 10:32 PM
tech7427's Avatar
according to the ETM that is the right order and colors sir.
Old Dec 15, 2008 | 10:33 PM
tech7427's Avatar
the only thing i can think of is that when you cut the wires you just didnt match them up right when re-connecting them, like say, red - blue instead of red to red.
Old Dec 16, 2008 | 08:46 AM
95dc2teg's Avatar
well i know the polarity of the wires doesnt matter, i.e. i have after market injector clips that came with pigtails and both of the wires are white.
Old Dec 16, 2008 | 09:25 AM
irishflame27's Avatar
the yellow with a black stripe is the ground, the colored wire is the power wire, just double check all connections but it sounds like u did everything correct just might not have a solid connection.
Old Dec 16, 2008 | 02:53 PM
95dc2teg's Avatar
alrighty i figure it out. since i have hondata and the sensor for the water temp was broken that is why the check engine light was sort of flashing. also my idle air control valve needs to be cleaned... everything is running great other than that, thanks guys!
95dc2teg
Dec 15, 2008 08:47 PM
dem0nk1d
Aug 16, 2007 02:58 PM
Tippyman
14
Mar 27, 2006 08:55 PM
Mr. Vapor
Apr 27, 2005 12:29 PM
Excelerate
Oct 27, 2004 10:02 AM
