5th gen will not idle! I've searched.
My prelude has 240 compression across the board. Spark/Air/Fuel. What could cause this problem? The car is able to be driven but once it reaches operating temperature it will not idle. Since I am running an H22A. I had to replaced the H22A head with a H22A4 head, and I am using a H22A4 head gasket. Could it be the H22A4 head gasket? The H22A head has been rebuilt and I have the correct gasket. Do you think swapping out the H22A4 head for the original H22A will fix the problem?
The same thing happened to me! Turns out #16 and #24 vacuum hoses were crossed at the left shock tower. This caused the EGR valve to stay open because it coudnt bleed off vacuum. Check it out.
TachiKun
Mar 28, 2016 11:28 AM
