tps wierd volt readings
Old Dec 15, 2008 | 11:30 AM
blowoutj00si's Avatar
Default tps wierd volt readings
just got my swap done a couple days ago h2b f20b in a 99 si. i got two cel's on start up.
cel 3 map and sell 7 tps. the map was because i had the positive and negative swapped. so i swapped them around and no more cel. the tps is alittle different. i used my multimeter
and was getting 5v positive and 5v on sensor when the tb was closed. when i went to wot it droped to .45 v. shouldn't that be the other way around?? i did take the tps off before i put the motor in. is there any way i could of put back on wrong???
Old Dec 15, 2008 | 01:46 PM
mortificationrock's Avatar
Since your getting CEL 3(MAp sensor) and & (tps) im guessing you have the plugs swithced around. Unplug them and swith the tps and map and that should fix your problem.
hondalove414
Mar 20, 2011 08:11 AM
Running925
Nov 14, 2006 07:57 AM
Punker1234
Feb 4, 2006 01:20 PM
minititan
Jul 13, 2005 05:02 PM
