another redline problem
Old Dec 14, 2008 | 09:23 PM
MI4$DC5's Avatar
Default another redline problem
car:
94 dx
ob2 b16 converted to obd1
running a chipped p28
I swapped in the b16 into my car and took it for a spin and how she doesnt want to rev over 5500rpms
i have no CELs and i have changed out my dizzy for another one and its the same outcome. This is really getting on my nerves. any suggestions or has anyone else have this problem
Old Dec 14, 2008 | 09:30 PM
youryanyou's Avatar
have you tried a different ecu?
Old Dec 14, 2008 | 09:33 PM
andoxviii's Avatar
Yeah, it might be a chip problem. Try another ECU.
Old Dec 15, 2008 | 06:27 PM
MI4$DC5's Avatar
i tried a stock p28 cause thats all i have and its the same problem. what is a stock p28 redline?
Also i took a VSS from a SOHC tranny and put in my gsr tranny if that makes a difference?
Old Dec 15, 2008 | 07:00 PM
1badteg's Avatar
stock redline is 7200 i believe. it could be timing, bad oil sending unit or vtec oil sensor. though these may not limit your rev to 5500. vtec hits at 4800rpm. if your engine isnt getting the right oil pressure then the ecu may limit the power to prevent damage. check your wiring too. im just throwing ideas out so good luck.
Old Dec 15, 2008 | 08:35 PM
iamthefollower's Avatar
actually the redline hits on a stock p28 at 7800, but it sounds to me like there is something going on with your wiring..
Old Dec 16, 2008 | 04:21 PM
MI4$DC5's Avatar
wiring?? ill start at the oil pressure sending unit. i guess all i can do is start replacing parts i guess.
Old Dec 16, 2008 | 08:26 PM
are you sure you have your vtec wired into the right pins on the ecu plugs?
Old Dec 17, 2008 | 08:19 PM
MI4$DC5's Avatar
yeah, ill go double check
Old Dec 18, 2008 | 06:38 AM
ok, after you check it, let me know and we'll try another problem..
Old Dec 18, 2008 | 09:22 PM
MI4$DC5's Avatar
the wires are good. im going to check my tps tomorrow
ensang_phamily
14
May 31, 2009 11:46 PM
Nace325e
Apr 7, 2009 04:32 PM
Tealeg88
19
Jan 20, 2006 06:00 PM
andreysibiris
Jul 31, 2005 02:44 PM
ls95hatch
Jul 17, 2003 02:13 AM
