B20 swap in 95 civic dx.....need a little help
Old Dec 14, 2008 | 09:46 AM
jdmvtecej2's Avatar
Default B20 swap in 95 civic dx.....need a little help
about to do a b20 swap in my cosuin's eg.............which harness do i use, which ecu and i use integra mounts, back bracket and axles right? if there's anythig else i missed please tell me
thanks
Old Dec 14, 2008 | 10:32 AM
jdmvtecej2's Avatar
bump
Old Dec 14, 2008 | 11:09 AM
boostedcivicsir's Avatar
Mr. Badwrench
use your harness. it is easiest to use the harness out of your car. ls ecu, teg mounts. teg back bracket, teg axles.
Old Dec 14, 2008 | 11:36 AM
jdmvtecej2's Avatar
thnks bro.....but what if its obd 2?
Old Dec 14, 2008 | 12:17 PM
jdmvtecej2's Avatar
bump
Old Dec 14, 2008 | 12:39 PM
saywhat's Avatar
You are running it in an OBDI chassis so you don't have to worry about the additional OBDII sensors.
Old Dec 14, 2008 | 01:22 PM
jdmvtecej2's Avatar
ok thanks
Old Dec 14, 2008 | 02:25 PM
94EG8's Avatar
Seagull Management
Yeah, but you do have to worry about different injector, alternator and distributor plugs. The absolute easiest thing to do is use a '96 - '01 USDM integra engine harness, any model.
My#1teggy
Honda CR-V & Element
May 22, 2019 02:28 PM
2000 EK
12
Nov 18, 2011 02:37 PM
CivCruise
Jul 24, 2009 11:01 PM
slo_ej8
Apr 8, 2008 12:36 AM
cas95
Nov 20, 2006 01:12 PM
