D16y7 heat shields
Old Dec 13, 2008 | 02:55 PM
Riced-EL's Avatar
Default D16y7 heat shields
Hello, been trying to get the heatshield off...Its been rattling like mad. I am trying to get the pieces on the cat off and now I have the front of the shield off. But the part that faces the enging block, won't budge. If it helps at all, this is a 2000 Civic SE hatchback.
Old Dec 13, 2008 | 02:58 PM
andoxviii's Avatar
Like me, you have one of the rarer Civics This model is only available in Canada, and only in 2000.
Sorry, can't answer your question, though...
Old Dec 13, 2008 | 02:59 PM
Riced-EL's Avatar
LOLLLLLLL thx!!!
On a side note, I have disassembled the header from the block...only to be stupid to realize I wont be able to pull it away from the block far enough without the stupid AC blocking me...So i need to find some other solution....
Old Dec 13, 2008 | 03:14 PM
THEJDMWAY's Avatar
DrEmEl
It's your friend....
G/L
Old Dec 13, 2008 | 06:13 PM
Riced-EL's Avatar
there has to be other ways!!! I dun wanna go out and buy a dremel!!!
Old Dec 13, 2008 | 06:48 PM
94EG8's Avatar
Seagull Management
Originally Posted by Riced-EL
LOLLLLLLL thx!!!
I haven't specifically done a Y7 in a civic with A/C before, but you should be able to get it out of there, you can probably lower it down below the car after you unbolt the downpipe from the intermediate pipe.
Old Dec 13, 2008 | 09:38 PM
Riced-EL's Avatar
I thought about doing this. However I have no clue what size the 3 bolts are. Its currently really messy outside and everytime I climb under the car, all I get is salt in my eyes. So if any1 has any idea what the proper bolt size is, then feel free to say...
jimmyizcool
Oct 31, 2007 03:45 AM
jrap1243
Oct 16, 2007 09:35 PM
rmcdaniels
13
Aug 13, 2005 07:22 PM
JMinSi2000
Apr 14, 2002 05:32 PM
