Crankshaft Pulley Bolt access problem...
Old Dec 13, 2008 | 01:59 PM
firaga21's Avatar
Default Crankshaft Pulley Bolt access problem...
I have the Honda Pulley Removal Tool but it the frame is in the way, it seems the tool is too deep. I have Eibach lowering springs but dont think that should matter cause its on jackstands anyways. How can I get this thing in?
Old Dec 13, 2008 | 02:12 PM
under a rock's Avatar
Try removing the drivers side motor mount. It should allow the motor to lower down enough to allow the tool to work. Hope this helps.
Old Dec 13, 2008 | 02:29 PM
firaga21's Avatar
Thanks, would that be the only other way? Also, has anyone seen a crank shaft pulley get loose by itself? Ive had this car 3 months and just now discovered it by looking for where this weird metallic sound was coming from?
Old Dec 13, 2008 | 02:46 PM
That's the easiest way to do it. Its real simple. I've read a couple of cases of the pulley loosening by itself. Good luck with the fix!
Old Dec 13, 2008 | 02:55 PM
firaga21's Avatar
Thanks alot!
bradley
13
Jan 9, 2012 02:12 PM
goldfinger93030
Feb 13, 2010 06:39 AM
bseriescrxsi
Mar 31, 2008 12:11 PM
98civic94gsr
Mar 10, 2006 09:26 AM
accord2fix
Jun 7, 2004 10:57 PM
