b20z bottom, gsr head
Old Aug 3, 2002 | 07:53 AM
BigBlockCRX's Avatar
New User
Default b20z bottom, gsr head
so Ive heard everything from 'the pistons will hit the valves' to go ahead, it works great!
Yes or no
Old Aug 3, 2002 | 08:08 AM
Booger's_Rex's Avatar
Default Re: b20z bottom, gsr head (BigBlockCRX)
it works. we got a cr-vtec and it does not hit on the valves or anything.
[Modified by Booger's_Rex, 12:09 PM 8/3/2002]
Old Aug 3, 2002 | 02:41 PM
hybridmoose's Avatar
Default Re: b20z bottom, gsr head (Booger's_Rex)
If you ar using a GSR head you are completely fine. The GSR head has 31mm valves where as the B16a head has 33mm valves. The pistons in the B20 have valve reliefs for 31mm valves therefore you are cool with a GSR head. If you use the B16A head the only problem you will encounter is that you cant advance the cams more than a few degrees or else the valves will tap the pistons. Hope this helps some.
Old Aug 3, 2002 | 03:00 PM
Kamin's Avatar
Default Re: b20z bottom, gsr head (hybridmoose)
http://www.crvtec.com
http://www.c-speedracing.com
start reading.
Old Aug 4, 2002 | 12:38 AM
InfamousRS's Avatar
Default Re: b20z bottom, gsr head (KAMiN)
What about b20z pistons with a b16 head milled .030 and 200 JDM ITR cams w/stock cam gears?
Old Aug 4, 2002 | 01:38 AM
Kamin's Avatar
Default Re: b20z bottom, gsr head (InfamousRS)
dont mill the head
and you might have problems with the ITR cams if you advance your timing more than a degree or 2
while the head is off the b20, cut the valve reliefes 2-3 mm
Old Aug 4, 2002 | 10:51 AM
InfamousRS's Avatar
dont mill the head
Well the head is already milled .020.....The guy who had it before me had it p&p and milled at the same time. How would I cut the valve relefes? With a dremal?
Old Aug 4, 2002 | 02:04 PM
No-Gi's Avatar
dremmel and lots of patience.
Old Apr 19, 2005 | 11:15 AM
HomeDepotMade's Avatar
Default Re: b20z bottom, gsr head (3_South)
hey anyone know where to get a b20b/z end block? in socal? i dont want the whole engine just the bottom.
luly-rast
Nov 15, 2011 12:12 AM
baynedo
Mid-Atlantic (Sales)
May 27, 2011 01:55 PM
quick Dick
Mar 30, 2008 02:00 PM
SLow-Side
Oct 23, 2004 06:56 PM
gsrjay
Sep 2, 2004 05:05 AM
