RC injectors dont fit?
Old Dec 12, 2008 | 06:19 PM
b20beast83's Avatar
Default RC injectors dont fit?
I have rc 550cc injectors.
They will not fit inside the manifold.
They are too big.
Has anyone experienced this problem?
Motor is a b16a.
What can i do
Old Dec 12, 2008 | 06:22 PM
postman's Avatar
they sit on top of the grommets not in them
Old Dec 12, 2008 | 06:33 PM
mtber's Avatar
Take a picture of them, maybe you were sold injectors for the wrong application.
Old Dec 12, 2008 | 07:39 PM
dpetro1's Avatar
correct. the RC install sheet confirms this
File Type: doc
Old Dec 12, 2008 | 07:41 PM
Whatever's Avatar
I have the same injectors and it's pretty stupid the way they sit on top of the grommets. I had to use spacers on the fuel rail in order to not squish the rubber "cushions" at the top and bottom of the injectors.
Old Dec 13, 2008 | 11:56 AM
93egboosted's Avatar
yep had the same problem had to put spacers in. also had to connect the injector clips in before i tightend the fuel rail
Old Dec 15, 2008 | 09:56 AM
b16adx's Avatar
Mine fit. Just had to torque down the rail.
https://honda-tech.com/forums/showth...044&highlight=
Old Dec 15, 2008 | 04:45 PM
desiromeo812's Avatar
Inside your intake manifold there are 2 rubber pieces.. there is the soft one and the hard plastic one. Take the Hard plastic rubber out and just use the soft part... Then you can tigthen them up and dont have to use spacers or anything. Later
Old Dec 15, 2008 | 05:57 PM
Whatever's Avatar
That's what the people at RC told me to do but my JDM B18B only had the soft rubber pieces and no hard plastic ones...
Old Dec 15, 2008 | 07:22 PM
tech7427's Avatar
a+ for proper info
Old Dec 15, 2008 | 11:59 PM
boostnbee's Avatar
from what ive found if you put the rubber seal half on the injectors and half off then slide the whole rail down in with each ijector going into the manifold at the same time it makes a nice solid seal. the rubber ring will be in the mani and the bottom of your injector wil sit down in the seal when you tighten the fuel rail down
Old Dec 16, 2008 | 05:02 AM
blaze the chemi's Avatar
Go to your local acura dealership and only get the o-ring for a 92-95 acura. These will fit in your intake manifold and will be the PERFECT size for the RC injector.
Place the o-ring in the intake recess where the injectors go. Place the injectors into the fuel rail. Dap just a little oil on the inector where it will contact the o-ring for lubrication (KY optional). Line up the injectors to the o-ring and make sure they rest on top, do not try to force them in. Then bolt in the fuel rail and don't over torque those nuts. 8-10 ft-lbs is plenty.
I believe you get #4 in the picture. #14 is the small o-ring that makes the injectors snug with the fuel rail. These are cheaper than buying a kit from Pep boys. I never used the spacers with RC's
Old Dec 16, 2008 | 08:25 AM
dpetro1's Avatar
guys what is so hard about following the RC instructions that i posted? im sure there are other ways to make it work but there is no reason not to follow the directions.
Old Dec 16, 2008 | 11:08 AM
rmcdaniels's Avatar
Never mind, reading owns me.
HKSuperSi
Jul 1, 2008 10:12 PM
second edition
Apr 8, 2006 02:13 PM
JDM_Ej
Aug 8, 2005 12:32 PM
BoostedsiR
Jan 28, 2004 06:48 AM
b20ek
11
Jun 29, 2003 09:18 PM
