sound from my tranny need help!!!!!
Old Dec 11, 2008 | 09:44 PM
civicegsick's Avatar
Icon6 sound from my tranny need help!!!!!
yea so there is a whining sound coming from my tranny its really loud in 1st and 2nd gear but u cant even hear it on the freeway i thought it was my t/o bearing because it does go away when i put the clutch in...so i searched and found out that i could also be my input shaft bearing just want to make sure which one it is or can it be my tranny??....any help is appreciated o and it is 95 d16z6...thanx
Old Dec 11, 2008 | 09:49 PM
iamthefollower's Avatar
I had this problem with my old d series transmission, it ended up being my input shaft bearing. If it was your throw out bearing it would do the whining when you pushed the clutch in.
Old Dec 11, 2008 | 09:52 PM
is the input shaft bearing on the outside of the tranny?
Old Dec 11, 2008 | 09:54 PM
it's inside of the casing. you would have to take your tranny apart to fix this problem.
Old Dec 11, 2008 | 10:45 PM
andoxviii's Avatar
I had a bearing problem with my Y7 tranny...it was going to cost $900-1200 for a transmission shop to fix. It only cost me $150 to buy a JDM D15B tranny from a local importer.
Old Dec 12, 2008 | 03:40 AM
instructor74's Avatar
grab a service manual. I spent less then 150 and I replaced all the bearings and syncros. If your just doing the isb the job really is easy and not very expessive to do. if you can pull the trans and change a clutch you should be able to change the isb just follow the service manual and ask a lot of questions.
Old Dec 12, 2008 | 06:04 AM
jeremyrocksursox's Avatar
x2, if you want to do this by yourself OP, grab the helms manuel, you can find it at your local autoparts store, but if you've never worked on your car besides an oil change, i would take it to a shop. gl on your fix man
Old Dec 12, 2008 | 10:14 PM
Yeah i'm with the others on this one, the job isn't real hard and if someone is wanting to charge $900 or so to fix this then they are trying to rip ppl some new ones... ?? anyways, just get the manual and everything.. all you really need is a pair of snap ring pliers, a socket, rachet, and a little bit of time..
Old Dec 12, 2008 | 11:14 PM
99ej6gsr's Avatar
i have the same thing happening with mine too. is this something major that should be fixed or can the tranny still go awhile without fixing it?
Old Dec 13, 2008 | 09:44 AM
you could still drive it for a little bit, but if you just don't eventually try to get it fixed or get another transmission it could lock up inside of the transmission..
EKcpe00
Mar 25, 2011 08:50 AM
TurboedGSR
Transmission & Drivetrain
Sep 6, 2008 08:54 PM
88 rex
Aug 11, 2006 12:37 AM
Mr_Moos
Apr 19, 2005 10:07 AM
eg6r4eva
Dec 23, 2004 05:38 PM
