gsr b16 ????ssss
lol too much work and not enough power? hmm sure
just get a port and polish on the gsr head and throw ctr cams in there, then u'd be set over the b16 head.
a ported and polished b16 head on a GSR block would be a good setup, just as long as u put in some higher compression pistons. without the pistons, the C/R will drop a little bit.
out of those 2 heads, the b16 head will make more power if u use high lift cams! i will be doing this setup within the next few months. still saving for my b16 head to get the bath!
