Del sol Master brake Cylinder
Old Dec 11, 2008 | 10:24 AM
courtney42's Avatar
Icon2 Del sol Master brake Cylinder
I just bought a del sol that's missing the master cylinder.
I noticed while shopping for one online that there are two different kinds?
One for non Vtec non ABS model, and one for Vtec with ABS?
My Del sol is a 94 ans has disk brakes in the rear , not drums.
How do i find out if i need to get the ABS version of the master cylinder?
Do i have ABS?
Does anyone here know if it maters at all?
can i use any Del sol master cylinder that will fit?
Also does anyone know of any reputable brands or should i stick with OEM?
Thanks
Old Dec 11, 2008 | 10:53 AM
jc_chavez55's Avatar
So you have an si well the only civic that has abs is the ex-s which pretty rare so no you dont have abs i have a 94 del slo si and they do not come with abs...stay oem if you wanna save money but there is not really a point in upgrading it at all
call you local honda dealer they will give you just about every detail
Old Dec 11, 2008 | 11:14 AM
courtney42's Avatar
Thanks a lot man. You have been a big help.
I think i will be buying an OEM part off of Ebay then.
I'm amazed at the quick response.
WOW we both live in Austin!
Old Dec 11, 2008 | 11:23 AM
trustdestruction's Avatar
94-97 del Sol VTEC is the only one with ABS.
Old Dec 11, 2008 | 02:04 PM
itsmejto's Avatar
You only have to look to the right of the master cyl, theres a huge aluminum block with mucho wires and brake lines if it has abs.
Old Dec 12, 2008 | 11:45 AM
driveslow's Avatar
btw, I have had success using a remanufactured Master cylinder from Oreilly with out a problem. I know that some will not agree on going with reman stuff, but so far have never had a problem and they all come with lifetime warranty. If you have 170 dollars to spend, go with OEM Honda new. But for 29.99 you can get a remanufactured one from any parts store with lifetime warranty. Just make sure to bench bleed before installing. ATX!!
Old Dec 12, 2008 | 12:09 PM
instructor74's Avatar
I have done both reman and non oem new from parts stores never had a problem with either
mugen_sol
Suspension & Brakes
Nov 9, 2016 06:48 AM
1LowSol
Jan 11, 2009 11:56 AM
itsmejto
Aug 7, 2008 03:10 PM
SOLvtec
10
Oct 29, 2006 06:39 PM
