NEED HELP! ls/vtec stalling when warm
Old Dec 11, 2008 | 07:54 AM
masterjdr's Avatar
Default NEED HELP! ls/vtec stalling when warm
I know this most likely is an electrical issue but I cant pinpoint it,. I have a 94 Civic DX with ls/vtec swap. Lately (mostly during warmer days) my car will run about 15 minutes or then stall., all the dash lights come on, it wont crank up immidiately as take atleast a minute. sometimes longer before it will crank back up. During cold weather I don't have any issues. sometimes I will here a loud backfire pop from the exhaust then the power goes. so far Ive changed the Ignition Coil, and the distributor connection points seem to be fine. Checked all my grounds, and wires seem to be okay. does anyone have any suggestions.?? please help!
Old Dec 11, 2008 | 07:56 AM
blkegcoupe's Avatar
From: ....................................................................................................
Try a newer main relay.
Old Dec 11, 2008 | 09:42 AM
masterjdr's Avatar
I replaced the main relay 2 weeks ago, same thing.
Old Dec 11, 2008 | 10:31 AM
cliniCrx's Avatar
do you have a catalytic converter? if so check to make sure it isnt clogged.
CO_CReX
Aug 22, 2007 08:26 PM
Emmanuel2112
Jul 25, 2007 05:57 PM
DAVID_VARNER
Aug 8, 2006 03:23 AM
Db1_77
Jun 21, 2005 06:35 AM
Turbo'dMex-A-Keen
Apr 29, 2005 08:47 PM
