FS: Hydro b16 trans MINT!
Since my friend is going with an ITR trans i can post up this one.
Heres the deal, i bought the trans off BigZeke on Honda-tech, it had a 3rd gear grind. Took it to Mark @ one-6 Motorsports he fixed it. Put it in my car and never had a problem. I'm going a different route so this has to go.
-b16 Trans hydro
-VSS
-3rd Gear grind fixed by mark @ one-6 (350.00 bill)
-Bought the trans with the grind, got the work done @ one-6
-changed the fluid 3 times since i've had the transmission in my car. (5-6 Months)
-Changed with OEM honda trans fluid & once with GM syncromesh
-Linkage will not be included, but for an extra $100 i will throw that in
-zero leaks
-NO grinds
For $150.00 more you will get a Fidanza 7.5 lb flywheel & Exedy stg1 clutch
The clutch is pretty much new as well as the flywheel.
$600 FIRM
$700 FIRM with linkages.
so $850 Complete with clutch/flywheel/linkages
Paypal accepted.
Techneekone@gmail.com is my paypal address.
Located in Chicago, IL
Will ship @ buyers expense. shipping is well around $60.00-75.00 Depending where.
-b16 Trans hydro
-VSS
-zero leaks
-NO grinds
$600 FIRM
Paypal accepted.
thirsk66
Sep 7, 2013 12:22 AM
