rear disc conversion
Old Aug 2, 2002 | 07:46 PM
Paradox's Avatar
Default rear disc conversion
I have a 98 CRV. Unfortunatly it has rear drums and I would like to convert it to disc but I cannot find a conversion kit out there. I have checked both AEM and Brembo, niether of which will work for me.
I was wondering if I could use parts off of another 5 lug Honda. And if I did that, what all parts would I need. Thanks in advance.
-Josh
Old Aug 3, 2002 | 07:26 AM
Paradox's Avatar
Default Re: rear disc conversion (Hector878)
bump
Old Aug 3, 2002 | 03:49 PM
Paradox's Avatar
c'mon people, think
bumpity bump bump
Old Aug 3, 2002 | 08:40 PM
Paradox's Avatar
i give up
Old Aug 3, 2002 | 08:41 PM
Kamin's Avatar
why does your crv need rear disks so bad?
Old Aug 3, 2002 | 08:52 PM
Paradox's Avatar
Default Re: rear disc conversion (KAMiN)
Its a feature that i would like to have. the more stopping power, the better.
I would like to get more HP out of the motor, but I would need to be able to stop the vehicle too.
Old Aug 3, 2002 | 08:57 PM
piscorpio's Avatar
no trim of CRV has all disc brakes?
What about the MDX, are the two platforms similar enough to use its brakes? (Im not even sure it has all disc either, Im just brainstorming a little.)
Old Aug 3, 2002 | 09:26 PM
bmm89's Avatar
Default Re: rear disc conversion (piscorpio)
mdx is another platform and those brakes won't work. Have you tried the brakes off an civic ex. Thay may bolt on since the crv is basically a civic. Also the aem conversion "may" fit, not sure but junkyard rear disks off a civic is cheap...
Old Aug 3, 2002 | 09:30 PM
Paradox's Avatar
Default Re: rear disc conversion (bmm89)
CRV = 5 lugs
Civic = 4 lugs
Old Aug 3, 2002 | 09:39 PM
Kamin's Avatar
the rear brakes dont do much man
the fronts is what you need to worry about
boostedbatch
Oct 3, 2010 01:31 PM
b20_driven
Jul 16, 2009 04:19 PM
b16pwrdeg
Mid-Atlantic (Sales)
Jun 11, 2005 02:32 PM
MokujinX5
Dec 16, 2003 02:50 PM
Guam_CiviC619
Aug 14, 2002 11:51 PM
