The BEST transmission setup (gearing wise)
Hey ht, i am looking for the best transmission setup (gearing wise) for my setup. I daily drive my car everyday in the summer time, so i was def thinking an ls 5th gear. I currently have a gsr (bone stock) trans in it. I do alot of thruway racing but i also race often on the dragstrip too. In 1/8th mile and 1/4.... But i do more thruway pulls 40 and up than anything...
So basically what would be the best setup for gears in my gsr transmission that will kind of suite all my needs??
Here is my setup:
Motor/Turbo Setup
GSR Motor 60k, 2k since rebuild
9:1 Comp ratio
JE Pistons
Eagle Rods
OBX Intake mani
ARP Head Studs
AEM 3 bolt cam gears
Borg Warner GM-8 turbo
New style SSAC mani
38mm wastegate
2.5 bar motorola map sensor
3 inch DP
2.5 inch charge piping
No name front mount
Chipped p06 with added Vtec trassistors and datalogging
880cc PTE injectors
B+M FPR
KKS SSQ BOV
3 inch catback
Sunpro Boost gauge/Autogauge oilpresure, and water temp. (On A-piller)
(I am currently running 16psi, I hit full spool around 3500rpm. And making around 400whp)
Here is my setup:
Motor/Turbo Setup
9:1 Comp ratio
JE Pistons
Eagle Rods
OBX Intake mani
ARP Head Studs
New style SSAC mani
38mm wastegate
3 inch DP
No name front mount
880cc PTE injectors
B+M FPR
KKS SSQ BOV
3 inch catback
for turbo, i'd say what you have is perfect..
if you need slightly more gearing. go for the 4.785 final drive.
what are your trap speeds? what speeds are you hitting when you are racing?
anything else might actually speed up your 1/4, but slow down any racing you do above 110 mph, causing you to shift into 5th and basically blow the race.
BTW, i doubt you'd like the LS 5th gear, honestly i think you'll regret it. stick with what you have. its the best alll around 5thgear
REDEM1FTW
May 12, 2011 11:45 AM
scspeed
Transmission & Drivetrain
Dec 10, 2008 09:13 PM
