91 integra biuld ls vtec
Hello,
My motor is an LS/VTEC. It is built, but leaks from the head gasket (below the vtec solenoid). Someone please help.
Thank you.
There you go, I helped.
p.s., as for your head gakset, if it is leaking, it needs to be replaced. If someone did the ls/vtec wrong (and didn't plug the oil supply hole), then it will leak. If you are sure it is leaking from between the block and head...the head will need to be taken off.
Thank you.
