B20V with GSR TRanny any good
Old Dec 9, 2008 | 09:37 AM
pmey's Avatar
Default B20V with GSR TRanny any good
well I try to kinda search for a thread like this but no luck
well my project car is up an running i still got a long way to go by my question is im running a b20v with an ls tranny right now and im planning to throw in my gsr tranny in next week, would i see a huge different in power compare to the ls tranny?
Old Dec 9, 2008 | 09:43 AM
weavertime1's Avatar
The power would be the same, however your gearing would be shorter therefore accelerating your car quicker. The GSR isn't a ton different than the ls, but it should be noticeable. The B16/ITR trans would have the lowest gearing of all of the B series trans. Good luck!
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
My friend had an LS tranny on his b20V, then when he got a b16 tranny it was WAY better. That **** climbs!
It will feel a lot better with the shorter gears.
Old Dec 9, 2008 | 10:08 AM
pmey's Avatar
well i dont know if it true or not peep tell my the the synco in b16 is smaller so when you put it in a b20v ur tranny tend go get messup faster where the b18c1 tranny have bigger synco
Old Dec 9, 2008 | 10:16 AM
Jas9848's Avatar
gsr trans is the way to go for a good balance between acceleration and highway cruising gas mileage. and it is a good choice in case you decide to go turbo in the future.
Old Dec 9, 2008 | 11:15 AM
Huh?
Old Dec 9, 2008 | 11:38 AM
slaminsam's Avatar
Originally Posted by weavertime1
Huh?
What he is talking about is the older cable b16 trannies.. The S1 for sure has a smaller input shaft and the synchros are diffrent than the newer models. As far as I know all of the hydro b series trannies have the same size shafts and synchros.
Old Dec 9, 2008 | 12:20 PM
BoltonGSR's Avatar
This is true. If you care at all about highway mileage stick with the gsr.
My GSR tranny on my B20 has me around 4000 rpm on highway trips at 75ish MPH.
B16/R trannys i believe will have you around 4500 at the same speed..
But yeah, youll notice a huge improvement especially at high rpm
Old Dec 9, 2008 | 01:25 PM
pmey's Avatar
thank for clearing that up for me -
eg_YANG
Jul 15, 2008 12:59 AM
EFM_ookie
Jun 2, 2005 06:10 PM
redDAinteg
May 16, 2005 03:17 PM
boostedeghatch
May 4, 2005 11:46 AM
