top mount manifold revhard or ebay cast manifold?
what manifold should i use in my 92 integra turbo with borg warner 57 trim will i see more power with a equal length manifold ? i hear stainless steel manifolds crack i found a top mount for 350 spa i think its cast iron is it worth it
the spa mani's are pretty good quality from what i've heard
there turbo's now thats another story
and guy before you say blah blah blah about ebay you should read the rest because i've yet to have seen a problem with spa mani's
hahaha bold statement, i have seen more gayhard manifolds crack then anything else... When you say the name revhard consider this is a company that uses ebay blow off valves, mild steel piping for the IC and DP, there down pipe is unflanged, has no flex joint or O2 bung... Why some people still think there a good company i willnever understand, they copied there manifolds from drag originally, copied there map diffuser from synapse, do i really need to go on?
the cast top mount is a decent manifold, it doesnt have a great collector, but there is somewhat of a collector cast into the manifold. more so than the revhard. i am not sure on fitment and clearance however.
I am going to use the spa top mount on my next build. It has a good design. I have seen a setup using the Panducky flange that turns the turbo straight like EL topmount. That setup had a/c and power steering.
But all this is just about the "kit" -- the OP asked about the manifold. The manifold itself is a proven design, and mine is still going strong without any cracks. My experience may be anecdotal, but I wouldn't hesitate to recommend the Revhard log mani to anyone looking for a dependable cost-effective option.
Gosh, I must've gotten an unusual setup when I bought Revhard 5 years ago. It's not a Fullrace setup, but it's not crap either. Mine came with a Vortech BOV (that still works) and a TiAL wastegate (that still works). I'll agree that the IC piping is marginal, but my downpipe was flanged and had one O2 bung. I did have to weld in a piece of flex pipe. And who uses the map diffuser anyway?
I can see how that could happen. I haven't seen any of there newest stuff, so I have no reason to doubt you.
Gotta say that there seem to be way more good options available now than there were just a few years ago. Just searching around here, the OP should be able to find plenty of info on who's stuff is built to last.
BoostAddictSRT
May 20, 2018 07:30 PM
B18ceed
May 31, 2006 12:00 AM
