OBD 1 to OBD 2 JDM Cluster HELP!!!
Ok I have a integra dash from a 94 integra so my under dash harness is OBD1. I just ordered a JDM cluster that worked in a 2000 integra so I am assuming the cluster is OBD2. Also all this is going in my 95 Honda Civic Hatchback which I believe is OBD1 also. According to litterboxe's write-up they say that if you want to use the civic underdash you can you just have to swap out guage cluster plugs. SO my plan is to use my civic underdash and splice OBD2 plugs for the cluster. Will this work? Does someone know if I can just match plugs for OBD2 cluster plugs to my OBD1 harness? Any help would be great!!! Thanks.
jdmcivicferio
Nov 24, 2002 05:05 PM
