Old Mar 25, 2015, 10:55 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
cat-back exhaust flange???
Old Dec 7, 2008 | 10:38 PM
notAdiesel's Avatar
Default cat-back exhaust flange???
anyone know where to find one of these? national auto parts and autozone both only have them welded onto the cat-back pipe, all i need is the flange
Old Dec 8, 2008 | 09:28 AM
Duane_in_Japan's Avatar
You will need to go to a muffler shop.
Old Dec 8, 2008 | 09:33 AM
Jas9848's Avatar
Most auto parts stores stock the flanges, but they keep them in the back. Most parts stores will ask you what car its for though and won't waste their time looking for it so it's best to try a muffler shop or order it off the internet.
Old Dec 8, 2008 | 09:39 AM
OK, and how is it going to get installed, will it seal the exhaust from leaks, is the pipe it is going to go over flared? Maybe some pics would help to clear up the issue.
Old Dec 8, 2008 | 09:56 AM
P_Adams's Avatar
Be sure you supply the proper info when you go beat up someone for this flange.
2/3 bolt?
Pipe Diameter?
It will help if you can make a template to compare to. An old flange gasket or a tracing will help.
You may have to gaff something (make do with a less than perfect item).
And all this depending on if the pipe it's attaching to isn't damaged / corroded to the point that it can't be welded.
P
Old Dec 17, 2008 | 11:46 AM
notAdiesel's Avatar
i have the catalytic converter already and brought it there so they could make measurements for some universal flange, but no luck. the cat is brand new, i need the flange on the left side of the picture
Old Aug 7, 2011 | 08:40 AM
tony4111's Avatar
Default Re: cat-back exhaust flange???
Hi..
How did you end up fixing this? Were you able to find a three point, triangular flange on the Internet? Did you take to a good muffler shop and they did it for you? How much was the repair? Or, did you replace the entire exhaust all the way to the back?
I have the exact same problem, where the B pipe flange rusted away and the catalytic converter's (new aftermarket one, and direct fit) has got nothing to bolt it to.
Thanks.
Old Aug 7, 2011 | 09:33 AM
chikin pickle's Avatar
It's just a standard 3 bolt exhaust flange.
campbuds
Honda Civic (2001 - 2005)
Nov 21, 2010 07:26 PM
ANDREW D
Sep 13, 2009 03:05 PM
SB97civic
Dec 31, 2003 11:10 PM
