Help: Cel 17 vss
Old Dec 7, 2008 | 09:15 PM
PaChiLa Leader's Avatar
Icon6 Help: Cel 17 vss
hi fellows,
its one after another.. i just fixed my code 90/91 by wiring up the 2 missing EVAP wires on my OBD2B to OBD2A jumper harness and now i got a new code.
Code 17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor.
basically i have an OBD2B chassis with OBD2A motor in it
everything works fine (cluster speed/rpm) but why would the CEL tell me my VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor??
any idea where to start??
once again my i have 00+ 5 speed cluster, if that matters, and everything works fine on it except the CEL is on.
thanks
Old Dec 8, 2008 | 07:33 AM
help
Old Dec 8, 2008 | 11:13 AM
weavertime1's Avatar
Sometimes the individual pins can be pulled out of the plug enough where they do not make contact. If this happens, it will throw that code. I got this code on my '99 CRV a few times, and I would just reset it. Nothing was affected, but it would come on intermittently. Come to find out the pin was just not making good enough connection sometimes. Good luck!
Old Feb 23, 2009 | 07:38 PM
wrx2civic's Avatar
Default Re: Help: Cel 17 vss
where is the plug to the VSS? i have an 89 HB with the same code??
Old Feb 23, 2009 | 09:02 PM
scbmx87's Avatar
The VSS is on top of the transmission towards the firewall, the plug should be somewhere in that general area. I believe its the only one of that size.
DeltaCharlie2
Nov 5, 2007 12:08 PM
GRPNHRD
Oct 1, 2006 04:54 PM
sireg6
Sep 26, 2006 01:38 PM
2-7offsuit
Jun 20, 2006 09:26 PM
Mr.Death
Jun 7, 2006 07:48 AM
