How much do you think this short block is worth?
Old Dec 7, 2008 | 09:04 PM
killacam661's Avatar
Default How much do you think this short block is worth?
b16a
bored to 85.5 with golden eagle sleeves and block guard
cp pistons 8.5:1
eagle rods wit arp bolts
stock crank
type r oil pump
with roughtly 15xxx miles on it..... THANKS
Old Dec 7, 2008 | 09:48 PM
RedneckRicer's Avatar
with that many miles and the sleeves being maxed out. i wouldnt make that investment
Old Dec 7, 2008 | 10:25 PM
GT35R_EF's Avatar
Make mine whatever you want
yea, thats the reason he is selling it probably. You would have no room to bore out if something happened.
Old Dec 8, 2008 | 12:02 AM
ABK's Avatar
ABK
$1000 if that.
Old Dec 8, 2008 | 01:58 AM
SD_Lurker's Avatar
HT White Ops
Originally Posted by ABK
$1000 if that.
its not even worth that. the block is pretty much done for any boosted applications.
Old Dec 8, 2008 | 06:13 AM
irishflame27's Avatar
ditto, the sleeves have exceeded that safe limit for boost, look elsewhere
Old Dec 8, 2008 | 06:15 AM
Schister66's Avatar
Man U FTW
Originally Posted by killacam661
b16a
cp pistons 8.5:1
stock crank
type r oil pump
Sleeves and a block guard..??
With 85.5mm sleeves, i would be staying away from it unless your goals aren't that high and the price isn't either
Old Dec 8, 2008 | 06:33 AM
amimaxima's Avatar
sleeves and a block guard?
Old Dec 8, 2008 | 06:40 AM
mar778c's Avatar
Community Builder
Community Influencer
Exactly, what I was thinking.
Old Dec 8, 2008 | 06:49 AM
amimaxima's Avatar
thats like an oxymoron
Old Dec 8, 2008 | 09:00 AM
HiProfile's Avatar
It wouldn't be bad as a ~300whp street car. It would be decent with a 60trim T3. VS a stock-sleeve B18B in a street car, it wouldn't be that great. You'd simply have more torque everywhere with the B18B, and the theoretical wear from the longer stroke's side-loading would be equaled by that 15k. You would also want a great cooling system, since the 85.5mm will be far more prone to blowing HG's due to heat.
For pricing purposes, I'd treat it as a stock-sleeve block with extra displacement. $1k might cover it, unless it was beat on the entire 15k. I've seen the GE guy here offer really decent prices to re-resleeve one of their blocks, but you'd still have to get new pistons afterwards. However, that would put you VERY close to the price point of building your own sleeved B18B, which would have 0.2L more displacement over that 85.5mm block.
Overall I'm always against sleeving a B16 (they'll never have the torque a longer stoke can provide), so IMO its junk.
Old Dec 8, 2008 | 09:06 AM
93CX's Avatar
Not much, because you'd have to find someone crazy enough to buy it.
Old Dec 8, 2008 | 02:43 PM
sorry guys it 84.5 mm....
So 15 thousand miles is alot?
And yes sleeves and block guard.
Old Dec 8, 2008 | 02:50 PM
its probally GE sleeved, and 84.5mm is perfect
Old Dec 8, 2008 | 02:54 PM
ya it GE sleeved for sure...
ok so you guys think the block is worth getting?
Old Dec 8, 2008 | 02:55 PM
96 GSR-T's Avatar
GE only charges $550 to re-sleeve one of their blocks if they did indeed sleeve the block you are mentioning, so even if it is over 85mm the block isnt done for.
Old Dec 8, 2008 | 02:56 PM
96 GSR-T's Avatar
depends on the price obviously, considering the amount of damage that could be done to a boosted motor in 100 miles, I personally wouldnt buy one with 15k miles on it.
Old Dec 8, 2008 | 03:07 PM
the whole motor was well taken car of...
the car was tuned on hondata s300 ,
but was only turboed for less than 5k miles, is it worth free ninty-nine?? Its a christmas present from a friend.... But for sure the motor is healthy and doesnt smoke.
Old Dec 8, 2008 | 04:09 PM
blwn95civic's Avatar
if you know the history of the block and trust the guy your getting it from then i dont see any issues... ppl boost stock blocks with xxx,xxx miles on them with new internals and dont have problems. I dont see how 15,000 miles on a sleeved block is hurting it any? There alot stronger than stock blocks and i'd boost a stock block with 15,000 miles on it without thinking twice.
Just make sure u know the bore to be sure... 84.5mm and 85.5mm is a pretty good difference when buying a sleeved block
Old Dec 8, 2008 | 04:15 PM
ya its for sure 84.5mm....
Old Dec 8, 2008 | 04:29 PM
TheShodan's Avatar
Moderator
Take out the block guard completely. Why have both? Doesn't work well at all. Make him take that out, as part of the deal.
Old Dec 8, 2008 | 06:29 PM
SD_Lurker's Avatar
HT White Ops
Im having a hard time believing its sleeved with the new GE sleeves and it has a block guard. Maybe if it was an open deck sleeve like Benson. I just don't buy that its the NEW STYLE GE sleeves with a block guard.
Old Dec 8, 2008 | 07:02 PM
CoreyR's Avatar
has anyone here even seen a GE sleeved block before? their sleeves have a built in "blockgaurd" which is nothing like the pile of **** blockgaurds people stuff into the tops of sleeves thinking its gonna help something. they are about halfway down the sleeve.
K20teggg95
Nov 4, 2011 06:44 AM
tsnunderground
Feb 7, 2006 05:04 PM
miller
Dec 16, 2003 02:30 PM
Civicdrgrcr
Nov 19, 2002 03:00 AM
InfamousRS
May 10, 2002 08:12 PM
