clutch problem? was in gear and car wouldnt move !
Old Aug 2, 2002 | 12:26 PM
hybrider's Avatar
Default clutch problem? was in gear and car wouldnt move !
im coming home from a friends house just a while ago,as i am entering the freeway, everything is fine, well minus the clutch pedal feeling a tad more 'softer' than usual, as i get into 5th gear i hear a styraphome (sp?) getting torn up kinda sound, then as i step on the gas, the car wouldnt move at all, i made sure i had gotten into gear correctly and i was...
i quickly pulled over, and everything was fine till i made it home just now
any ideas wtf this could be? also the clutch pedal the last few weeks, when slightly pressed feels softer than ever and then, has been popping back up violently (stock clutch) till today when this finally happened. Any ideas are well appreciated ppl.
Old Aug 2, 2002 | 01:31 PM
kinesistech's Avatar
Default Re: clutch problem? was in gear and car wouldnt move ! (hybrider93)
Once I was very angry and shifted HARD. I pulled my car around to wash it at work 8 hours later and found my clutch fluid level nearly empty. I bled it and it was fine. Any similar situations? How many miles on the clutch? Is it possible that its done?
Old Aug 2, 2002 | 04:20 PM
hybrider's Avatar
Default Re: clutch problem? was in gear and car wouldnt move ! (kinesistech)
fluids and what not are all up to par
also the last 3 weeks or so, i will just be driving and the clutch pedal will pop down all of a sudden, only to pop back up to its normal position a couple 2nd later (without touching it)
think the clutch is finished?
TIA
Old Aug 2, 2002 | 07:30 PM
hybrider's Avatar
Old Aug 2, 2002 | 09:50 PM
keebler65's Avatar
i thought the pedal got harder to push the more it gets worn down so in other words the softness you are getting wouldnt make sense to needing a new clutch, but thats just my opinion. do you notice it slipping like on launches/high rpm shifts?
Old Aug 3, 2002 | 12:13 PM
hybrider's Avatar
Default Re: clutch problem? was in gear and car wouldnt move ! (keebler65)
also when i clutch in and out when the car is off, i hear a kinda of a light screetching noise, kinda like wiping windows with a towel kinda thing.
Old Aug 3, 2002 | 12:18 PM
Kamin's Avatar
sounds like its on its last legs
just to be sure
flush the clutch fluid and replace it with new fluid.
but it sounds dead...sorry.
Old Aug 3, 2002 | 06:20 PM
Power1Pete's Avatar
Default Re: clutch problem? was in gear and car wouldnt move ! (KAMiN)
it could be bad slave cylinder.
LS_VTECteggy
Dec 21, 2009 05:22 AM
Cypher0117
16
Dec 9, 2009 08:36 AM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
Jeff_B
Dec 10, 2004 09:21 AM
hybrider
Aug 3, 2002 12:53 PM
