d16z6 into ek hatch!! what do i need?!
Old Dec 7, 2008 | 07:04 PM
'96typeR's Avatar
Default d16z6 into ek hatch!! what do i need?!
okay.... i got a d16z6 long block from a 95 del sol (obd1) and its going into an 96 ek hatch (obd2). exactly what do i need to make it run with vtec?
Old Dec 7, 2008 | 07:17 PM
happyabortion's Avatar
well being obd1 you will need injectors and dizzy off your obd2 or you can convert them if you dont have obd2 ones. also obd1 vtec ecu and you will need to run wires for your vtec pressure switch and vtec solenoid. there are tons of how to wire vtec. its not bad at all to do what you want to do/
Old Dec 7, 2008 | 07:20 PM
user 98292739's Avatar
easiest way is to get an ex harness.
because if not you would have to run wires do a 3 wire to 2 wire iac and other things.
also you should get obd2a/b injectors from a y8 because the ones on your car are 190cc not 240cc
Old Dec 7, 2008 | 07:24 PM
'96typeR's Avatar
my dizzy from the y7 doesnt fit on the z6, do i have to get a vtec one? my fuel rail doesnt fit either on to the z6 intake manifold? and do i need a jumper harness and wiring harness or can i just use my obd2 non vtec wiring harness?
Old Dec 7, 2008 | 07:26 PM
'96typeR's Avatar
can i just use 99 ex vtec stuff onto the z6 to keep my hatch obd2 and vtec? or it wouldnt work?
Old Dec 7, 2008 | 07:36 PM
94EG8's Avatar
Seagull Management
You need to make a distributor using the D16Y7 guts in the D16Z6 case, there is no stock distributor that works, use this as a guide https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-rebuild-your-distributer-using-different-model-dizzy-2441044/ use your old OBD2 injectors, but use the Z6 rail. You can reuse your original harness and add wires for vtec, you will also need to convert from a 3 wire IACV to a 2 wire IACV. use this as a guide http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg you will also need to use a jumper harness and an OBD1 P28 ECU.
'99 - '00 civic harness do not work in '96 - '98 civics and vice versa.
Old Dec 7, 2008 | 07:46 PM
'96typeR's Avatar
so i can use my non vtec dizzy (internals) with the z6 vtec case?
Old Dec 7, 2008 | 08:02 PM
freakasis's Avatar
use a z6 dizzy and wire the y7 (or y anything) plug onto it, use an ek ex harness with a obd2>obd1 conversion harness and use a 92-95 civic ex p28 ecu. (or the del sol one if you have it) dont use the "guts" tequiniq just pull the pins outta the obd1 plug and put em in the obd2 plug, they wont fit perfect but well enough to work. or you can cut the wires and solddar/heat shrink them.
Old Dec 7, 2008 | 08:25 PM
i dont like cutting
so i run dizzy jumpers...they run about 25 bucks and well worth it IMO.
Old Dec 8, 2008 | 05:26 AM
94EG8's Avatar
Seagull Management
Yes.
I've tried the pinning and deping approach before, they just don't fit well enough for me. Its also not particularly hard to swap the guts between two distributors.
Old Dec 8, 2008 | 05:35 AM
Civictech97's Avatar
Taking the gutts out and swapping them over is not hard at all.
But however 25$ for a Jumper is well worth it.
Old Dec 8, 2008 | 06:41 AM
JDMrasta's Avatar
get a subharness off ebay run the pin to a P28 ecu
Old Jun 28, 2011 | 08:24 AM
DARKB20's Avatar
Default Re: d16z6 into ek hatch!! what do i need?!
lilshady6796
Jun 14, 2023 01:32 PM
gsr_b20b
Dec 25, 2011 02:06 PM
JDM8o9
Apr 27, 2011 02:49 PM
krysted9354
Apr 9, 2009 12:16 AM
BME1986
Sep 13, 2004 05:13 PM
