injector size help
i need help on what size injectors to go with. b18 c1 bored and stroked(85x95). 11:5 to 1 compression ratio. should i go with 440 or 550 cc injectors or do i even need anything that big.
example- i had 750cc injectors on my ls/vtec turbo build and i was only running 14psi and wasnt even using the full potential of the intjectors. but i got the 750s so if i ever threw a set or pistons and rods in or uprgraded anything else that when i got re tuned again i wouldnt have to be buying new injectors again as well.
