OBDIIa or OBDIIb
Old Dec 7, 2008 | 09:31 AM
FunnyVictor86's Avatar
Default OBDIIa or OBDIIb
search engine is currently not working for me ... anyway for those of you who dont already know, i have a 2001 accord ex ... f23a4 SOHC ULEV blah blah ... im trying to do some research before i start my h22 swap ... i already know ULEV has a slightly different wire harness than that of a non ULEV f23 ... now my question is ... is my car a OBDIIa or OBDIIb?
Old Dec 7, 2008 | 09:32 AM
LightWeightChamp's Avatar
it should be obd2b
Old Dec 7, 2008 | 11:05 AM
i will be swapping a h22a1 to be specific and run a obdI ecu because of the immobilizer issue until i get a hondata s300 ... im going to use a jumper harness obdIIb to obdI ... and being that my harness has a couple extra wires from the ULEV feature should i assume there is going to be issues with the jumper harness? because not all obdIIb ecu's have ULEV right?
Old Dec 7, 2008 | 12:07 PM
TheMuffinMan's Avatar
He knows where you live!
Your car is OBD2B, Shouldn't have any issues running something like:
http://www.boomslang.us/obd2to1.htm
Same company I used and the harness looks just like that
If you have extra pins in there for ULEV stuff (none off the top of my head I could think of though) it shouldn't matter as the rest of the pins should be the same. You could just ask the Boomslang guys with your order for sure however. If you're changing out the ECU and Motor then it's not going to matter about those extra sensors - assuming the rest of the ECU pinning is the same.
Old Dec 7, 2008 | 02:02 PM
well im changing out both the ecu and the motor ... im just trying to keep my same harness, even though i know it would be easier to just get a harness from a h22a1 and i just might if i can find one dirt cheap ... i just realized i can use my wire harness from my spare f23a1 non-ulev ... and just get the obd jumper
Old Dec 7, 2008 | 02:19 PM
jweller's Avatar
I'm pretty sure there is no difference in the wireing harness between the ULEV VTEC(f23a4) and the regular VTEC(f23a1) motor. the ECU is different, but I can't think of any wireing differences.
and it is a 2B car either way.
Old Dec 8, 2008 | 10:42 AM
thanks for all the help everyone ... well i guess ill just have to wait and see on that ... now i have to figure out how im going to get the driver side mount to work ... ive read that you can use all accord mounts fit dead on except that driver side ... and solid mounts are rather hard to find for a f to h swap
Old Dec 8, 2008 | 11:00 AM
AFAccord's Avatar
There ARE a few differences in the pin-out between A1 and A4.
I went from a stock ULEV Accord to a stock LEV A1 motor, then OBD1 conversion on the LEV motor. I didn't find them for quite a while after I swapped to OBD1, but they are there. The first one I can think of off the top of my head is the O2 sensor pins are all different. I know there were more, but I'll have to look at my harness tonight to get you the specifics.
Old Dec 8, 2008 | 05:50 PM
sweet i definately appreciate the help ... would it be easier if i just used the harness off a f23a1? that way i dont have to deal with wiring aside from the jump from obdIIb to obdI itself?
Old Dec 8, 2008 | 05:58 PM
AFAccord's Avatar
PM'd for copyright reasons. I'll post up an explanation in my own words tomorrow.
Old Dec 8, 2008 | 06:04 PM
AFAccord's Avatar
I don't do H swaps, so I can't help you out with the wiring there. Once I figured out what I was doing, taking the F23A4 harness to an OBD1 friendly setup was a pretty simple process of swapping two or three wires on the factory harness ECU plugs.
Since your car is a 2001 model, your ECT gauge won't work immediately after the OBD1 swap. You'll have a couple options to fix that if you'd like, but that's another topic all together.
Old Dec 9, 2008 | 05:00 PM
what do you guys think is this a good deal ... a jdm h22a1 motor for $900 no tax ... not sure exactly what mileage but i was told low mileage ... guaranteed to start up and run with no problem
Old Dec 9, 2008 | 05:10 PM
Sounds like it's just the block/head probably no tranny/ecu for that price.
Old Dec 9, 2008 | 05:32 PM
nope ... just complete head and block ... thats why i will be using my harness with a jumper ... my trans ... and i have to get a regular obdI for my application ecu until i get a s300 hondata ...
as far as motor mounts ... all i could find are innovative mounts ... how are they anyone have them? here's a link to a site that carries them and has information on them:
http://www.swapshopracing.com/index1...13717234793977
Old Dec 10, 2008 | 05:12 AM
jweller's Avatar
you can do the swap with stock mounts. You don't need the innovative parts.
not sure if you knew that or not, so just thought I'd mention it.
Old Dec 10, 2008 | 05:16 AM
yes i know but i just dont want something i can depend on ... peace of mind you know
Old Dec 10, 2008 | 02:29 PM
AFAccord's Avatar
It's my understanding that you can order them in different harnesses, but the people I've talked to who have them say they feel like solid mounts, and the car vibrates like a race car.
I have ES Poly inserts in my OE mounts with a 9lb flywheel and used to have my balance shaft belt removed, but I often wish it was completely back to stock. The vibration at idle with the A/C on or around town starting off in 1st sometimes even gives me headaches. It's great for launching, but I can't imagine having full poly mounts. I'd go crazy.
EDIT: I'd atleast get an H23 tranny for that motor. The F trans wouldn't do it justice.
Old Dec 10, 2008 | 05:07 PM
i wouldnt want my bolts to rattle loose lol ... hmm its a tough choice ... i dont think stock accord mounts would hold up ... i mean mine are already done as it is with the f23 ... well eventually im going to get the matching trans and lsd ... but im on a budget
BOOSTEd2
13
Mar 28, 2011 04:56 PM
h-duced
Jan 17, 2008 03:27 PM
turboed4life
14
Mar 27, 2004 07:40 AM
who00knows
16
Sep 23, 2002 08:15 AM
