help! ek wont go into gear
this morning, tried putting the car into gear, and it wouldnt go. pedal feel is very soft, and takes a second for the clutch pedal to return. im thinking its the clutch/slave cylinders. any body have any insight?
Check the fluid. If it is there, try gravity bleeding it for a second or 2. Just crack the bleeder screw and let it drip. tighten the screw then start pumping the pedal like crazy, this can take some time to bring the pedal back. Check the slave and see if there is fluid on it before you bleed it, then you can check under your dash where the clutch pedal is and see if you can see any visible sign of a fluid leak on the firewall.
trippsEF9
10
Feb 10, 2013 01:29 PM
civictype-r
16
Mar 30, 2007 06:37 AM
